      oil pressure sending unit leak?
      I finally got my LS1 in my 72 Firebird; everything is a-ok, EXCEPT for this weird oil leak I have coming out of the sending unit at the back of the engine.
      This is an analog gauge and I think it's a nylon tube. I tightened the thing down a little tighter than hand tight and put teflon on the threads so I have no idea why it's leaking. Anyone have any ideas?
      Someone mentioned to use a copper line to replace the nylon line and that you could get this at the parts store - does anyone know if this is a kit or what this copper line is called?
      Here's the leaking part I'm talking about:
      And this is just to give you a reference of where it is on the engine:
      I am aware of the PCV hose disconnected. I did that because the hose was in the way when I took the photos.
      Thanks for any help/advice, I'm so close!!!
      San Antonio, Tx
      you have the tube stuck through the nut then the crush sleeve about a half inch? they do need to be pretty tight even thought its only plastic tube.
      Instagram: CamaroAJ
      Quote Originally Posted by CamaroAJ View Post
      So do you think I should just crank it down more at the tube nut? Or at both locations (the tube nut and the at the engine)?
      Got it all fixed. The nuts were loose and weren't making a seal AT ALL. I cranked them down, went for a drive, checked it, and dry as a bone! Thanks for the help.
      Phoenix
      Might want to consider the switch to a copper line still. That nylon stuff long term makes me nervous and boy does it make a mess if it breaks. Glad it was an easy fix for you.
      Erik
      https://www.pro-touring.com/showthre...without-a-name
      Camaro LS2, T56, 12 bolt, C6 Z06 brakes, Rushforth Super Spokes, ATS Spindles
      2006 Chevy Trailblazer SS
      Quote Originally Posted by ErikLS2 View Post
      Good point. I will probably do that in the near future. Any idea what that copper line is called at the parts store?
