    Results 1 to 17 of 17
      Nov 2010
      Fuel pump sending assembly for spectra tank GM32AFI
      New to this site, so i will give a little background info. Have 69 Camaro Convertible that i swapped over to a 96 LT1 and new FI tank from Paddock. Been having a lot of trouble with fuel starvation when below 1/2 tank. so i pulled it back out over the week end to see how the ank was made inside. Did see the bowl in the tank, but there were no holes in the bowl to allow fuel to get in except from over the top. After talking to a friend that builds FI street rods he says when building his tanks he puts 4 -3/16"to allow fuel to get in but won't let it run away the pump fast enough to stare the pump. So i did this. After putting it back into the car my fuel gage is not working. So I'm assuming i damaged the sending unit while reinstalling. So now to my questions, does anyone else have the same issues with this tank. The tank is a Spectra Premium GM32AFI but no where could i find the part number for the pump sending assembly. does any one know what the number is, and where to get one. Rock Auto has many spectra units listed but could not find one that looked just like mine.
      North Bend, WA
      There's a lot of information on this site about people having starvation issues and fuel level reading issues on those tanks.
      There's also a recent thread that talked about Spectra may be resolving the issues soon with revised tanks.
      Can't help ya on the assembly part number, but I'd try to contact Spectra if I were you. If they do release a fix the part numbers might be different for the improved assembly.
      Mike
      Nov 2010
      I could not get a hold of Paddock, so i called customer service at Rock Auto. they were very helpful, I gave her the tank number, and she found out the sending unit number, without the pump for me. So i will pull the tank again and make sure it's bad, if so I'll order one . Thanks, anyway. I read a couple of threads about these tanks, and they said they were great. But If they were designed like mine, I don't see how. Or maybe I've got a different problem.
      Jan 2007
      SOCAL
      Mine pumps fuel fine, but the sending unit is crap. Going to pull it out for the 5th time. Contacted Rock auto to see what they can do last week. Waiting to hear.
      Nov 2010
      Let me know what you find out, can you tell what's going wrong with the unit, or is it internal. I will pull my tank this week end and see if i can tell what going on with mine. Due to the tight fit going though the hole in the tank i think i damaged mine putting it back in. when you pull your pump out does you bowl in the tank have any holes in it to allow the fuel to get in.
      Jan 2007
      SOCAL
      spoke with rock auto today. they are shipping a replacement at they just got in a new batch of tanks today. The price has also been lowered by $100 bucks. Ill take pics of the new one...inside and install. Hopefully this one remedies the issue.
      Nov 2010
      Thanks, that would be great, hopefullly i've got my tank issues solved, but still need to figure out why the sending unit quit working. Should be able to get to it this weekend.
      Aug 2009
      Whittier CA all day!
      @s4dustin, I am very interested to hear if the issues have been fixed. I'm currently working on an LS1/T56 swap into my 67 camaro and I need to get a tank that works. I'm not autocrossing but I hear the LS pulls pretty hard and may cause sloshing/starvation if baffle is not correct. Keep us posted...
      The "fix" is not likely to fix much. Post 46:
      http://www.camaros.net/forums/showth...34#post1522134
      Baffle is unchanged. Based on what I have read here about the vaporworx tank development I doubt it will ever be fixed. I think the only fix for these tanks might be to add a surge tank.
      Feb 2011
      Same post I did on camaros.net
      Hi guys,
      The new GM32 fuel tank are now available.
      I can't tell you when they will get to your local supplier but what we have in spectra right now is the new version of the fuel tank.
      We did the first production of the new design last week.
      In order to improve the tank, we added a baffle inside the bowl to limit the impact of fuel slush. This modification will be done to all of our classic injection system in order to improve the performance of our
      systems. We also looked for a specific position of the strainer inside the bowl.
      Holmes Hollow, Ontario Canada
      Nicholas, maybe you are the guy I was just talking to at Spectra but I was told a bigger pump (255Lph) like the walbro is in the works. When might we see that one?
      ____________________________________________
      Scott
      Newbury Park, CA
      Just a heads up. The pump provided in the Spectra tank will not support an LS engine. It does not have enough capacity to support a completely stock 350hp LS1 running @ 58psi/4bar.
      With the as-installed pump @ 45psi/3bar it will support 350hp naturally aspirated.
      Thanks Carl, that's important to know. Side note question, does your car have a manager? I just saw it on the cover of Super Chevy.
      So is there anyone running this tank with an ls and what did they do or what would you have to do to make it work?
      I spoke with a tech who told me it would handle around 500 hp on an ls.
      Mods, do you want to delete this post for me? It would be a better question for the ls crowd so I'll post it there.
      Scott
      Aug 2005
      Hamilton, NJ
      Nicholas, if you do work it out make sure you make tanks for all 3 versions of the 2nd gen, not just 70-73!
      Scott from NJ.
      Vent Windows Forever! ...
      Newbury Park, CA
      As posted at Team Camaro:
      Posted by Nickolas:
      5.7L LS1 should use a maximum of:
      79,49LPH at 4000RPM
      97,66LPH at 5000RPM
      118,10LPH at 6000RPM
      Our fuel pump specification is 115LPH at 3bar.
      End of post by Nickolas
      115lph = 30.4gph. At 0.5 BSFC and 6.2#/gal fuel density, the pump is capable of 372hp at 3bar, best case, and assuming 13.5v. With a rating of 350hp, there's 6% overhead room/excess pump capacity with an all stock LS1. That's not much. But....
      .....the LS1 does not operate on a 3bar system, it's 4bar. Hence, based on your pump data, any LS-series engine running a 4bar fuel system will require a pump upgrade.
      Newbury Park, CA
      No, but sometimes the car manages me.
      Let's leave the thread as it stands. The fuel pump does not know what engine it's supplying.
      Based on the information that Nicholas posted on Team Camaro the pump will supply as noted above.
      Feb 2011
      Understand I'm here to help your community.
