    Thread: Body Work Tools
      Dec 2010
      Apex, NC
      Body Work Tools
      I am going to tackle doing the body work on project TechnoStang. Basically a couple of floor pan patch panels and a decision on the quarters. A little rust on both wheel wells and a a crease on one. Planning to just do full quarters on both. I have a welder, plasma cutter and air compressor. That's about it. What else does everyone recommend? Thanks!
      Mountain Springs, Texas
      Get yourself something like this and a bunch of Roloc discs:
      http://www.autobodytoolmart.com/inge...k-p-11429.aspx
      A small cutoff wheel with thin discs is handy to have. A hammer and dolly starter kit is also a good idea.
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Apr 2010
      White Rock, SC
      I would suggest some spot weld drill bits and a panel separator knife. Drill out your spotwelds first (on the quarter panels to be replaced) before cutting any material out (this will brace the metal for the force from the drill and also minimize distortion on the metal that stays). Also get the Paintucation video on body panel replacement (Summit racing or Eastwood). Kevin Tetz is a good instructor and actually does a full and partial quarter panel replacement on a Mustang. Make sure you have had a Tetnus shot and good luck!
      Steve
      1967 LS1 RS Camaro (Project "OVRBDGT");
      1968 350 Camaro;
      1969 Chevelle SS-396
      Dec 2010
      Apex, NC
      Thanks!
      Feb 2011
      dallas, tx
      Anyone know the difference between ingersoll rand ir429 and ir429g reciprocating saw? I need to buy one this week
      Mar 2012
      Texarkana, TX
      Body hammers and some dollies will help too. If you can find a deal on a stud welder and puller, they are really great for areas where you can't reach behind to put a dolly.
      63 Biscayne
      Schwartz Performance Chassis
      My build thread: https://www.pro-touring.com/showthre...ht=#post916553
      Mar 2012
      Texarkana, TX
      When you buy a right angle die grinder, spending a little extra will get you one that is more efficient and uses less air. The aircat ones are pretty reasonable and don't use a bunch of air. The angle die grinder is one of my most used tools when doing body work. The 3M purple rolloc discs last significantly longer than the paper backed ones.
      63 Biscayne
      May 2014
      Quote Originally Posted by ssealeycpa View Post
      X2 even the spot weld cutters from HF are decent when used properly.
