Thread: Loosing pedal at low speeds
Starting The Transformation
- Dec 2004
- Greeley, Colorado
- 485
Losing pedal at low speeds
On my 69 Firebird I have a set of MP Brakes front disks with a their powerbooster and new master cylinder.
While driving the car the brakes are great when you are at speed. however as speeds get to about 20mph and below the pedal becomes very hard and unresponsive. You've really got to mash on it to get the car to stop.
The engine has a healthy cam in it but nothing that I would consider to be "wild." Could lack of vacuum be my issue here? I haev the vacuum line to the brake booster run from the back of the carb rather than the intake manifold.
Any thoughts on this would be helpfull. Thanks guys.
Jason Mounce
1969 Firebird | 2008 Corvette Z06 | 2008 Mustang GT/CS
06-03-2005 #2
- Nov 2004
- NW Arkansas
- 1,742
Do you have vacuum canister of any kind?
With the car in nuetral with your foot on the brake rev the engine you should feel the pedal move if it is a vacuum problem???
When you say not to wild.....what are the specs?KENNY DAVIS HOTRODS
06-03-2005 #3
- Dec 2004
- Greeley, Colorado
- 485
I'm not sure on the specs. This engine was put into the car about a month before I purchased it. The originall owner was turning the car into a street.strip car but fell on hard times.
The cam is healthy enough to need added compression and a larger stall. I wouldn't say it lopes like crazy but the idle is not smooth by any stretch of the imagination.
I do not have a vacuum canister or pump.Jason Mounce
06-03-2005 #4
- Nov 2004
- NW Arkansas
- 1,742
It sounds like a vacuum problem to me! I would try a canister??
KENNY DAVIS HOTRODS
06-03-2005 #5
- Dec 2004
- Greeley, Colorado
- 485
Would a canister be the best choice for possible road course events? I could definitely see it being effective in normal driving conditions but at track events it may not be the ebst choice? Any thoughts on this?
Jason Mounce
06-03-2005 #6
- Nov 2004
- NW Arkansas
- 1,742
You might want to go with an alternative setup....Hydroboost,manual,etc
I am not sure JLM maybe someone will give us another opinion??KENNY DAVIS HOTRODS
06-03-2005 #7
