    Page 48 of 48 FirstFirst ... 38 43 44 45 46 47 48
    Results 941 to 949 of 949
    1. #941
      Chicago
      Wilson Muscle Car Optima Battery Tray (04-06-22)
      I re-installed the WMC optima battery tray so I could work on the wiring going to the Battery.
      marty-mj
    2. #942
      Chicago
      Battery wiring (04-10-22)
      Before I started working on the battery terminal wiring I need to run to the auto parts store.
      On my way home I stopped at McDonalds for a McFlurry.
      Since wires tend to have strong memory so I made sure the ring terminal was on in the correct orientation.
      I am still amazed at the amount of tools used on every project.
      marty-mj
    3. #943
      Chicago
      Finally found the DSE Wiper wiring Diagram (04-10-22)
      Well, I am certain everyone has lost instruction for something. This time I lost the instruction for the DSE Wiper wiring
      harness and no one at DSE could find a copy of it for me as it was there Gen I kit. After weeks of searching I finally found
      it so today is the day that I will finish that project.
      I added a line clamp to the steering column bolt. However, I am going to have to drill and tap these so I can use a nut to anchor these.
      marty-mj
    4. #944
      Chicago
      Final Install of the EFI Tank Vent ( 04-15-22 )
      So everything from here forward should be final install which is awesome as I really want to start this car.
      Jay at Pro-Tek Powder coating does such an incredible job powder coating yet I am still amazed at how nice stuff looks when it comes back from him.
      Of course the I had to write myself another reminder note.
      I did at a tiny bit of RTV on the bolts holes just to prevent and water seepage.
      So I picked up a new toy and some animal crackers.
    5. #945
      Chicago
      Element Fire Extinguisher (( 05-01-22 ))
      I picked up a Element Fire Extinguisher which will be mounted to the cross bar on the Tiger Cage.
      marty-mj
    6. #946
      Chicago
      ARP Trans Pan Hardware ( 05-05-22 )
      I was in need of a couple simple projects as work has been really busy lately.
      I also tracked down a roll cage bracket for the Element Fire Extinguisher.
      marty-mj
    7. #947
      Chicago
      AAW 500875 Hi Amp Alternator Charge Wire Install ( 05-07-22 )
      Out comes the passenger side header
      Out with the old.
      marty-mj
    8. #948
      Chicago
      Final Install of the Vintage Air Valve Relocation ( 05-08-22 )
      Next up is the installation of the Vintage Air unit and relocating the valve to the inner fender so it will be easier to service if needed.
      So up to the garage attic I go and it's starting to empty.
      This is the valve I will be relocating.
      Since the valve was located in the interior I need to extend the wires out to the inner fender.
      I need to enlarge the middle hole to 1/2" so somehow I was able to make a close to perfect circle with a dremel tool.
      My buddy Jimmy stopped by to check on the progress and show me the new exhaust he built.
      Mocking things up.
      Making things pretty.
      - - - Updated - - -
      About a year ago Tobin from Kore3 Brakes sent me the new brake lines and I finally decided to install them.
      marty-mj
    9. #949
      Feb 2006
      Southern California
      Great Post Marty! Greatly helps me with mine!
      Ron
      "If at first you don't succeed Skydiving is not for you"
      1970 Z28
      Scott Mock C6 Subframe, Ridetech RJoint 4 link
      LSX454
      Anvil Auto - through the build
