    Page 44 of 45 FirstFirst ... 34 39 40 41 42 43 44 45 LastLast
    Results 861 to 880 of 949
      Sep 2017
      Looking like some great progress Marty.
      Jason
      TANKMASTERJ
      Jasons Toys
      2000 HD Softail
      Man looking good... the CF looks awesome...
      Chicago
      Quote Originally Posted by qnitro View Post
      Thank you Kevin and thankfully I bought all of the carbon stuff during the first build as with two girls in college that would not be in the budget.
      marty-mj
      Chicago
      DSE Top Post Battery Terminals ( 02-13-22 )
      So I have finally decided that I am going to use the DSE battery Terminals as they are the nicest looking and I just like them.
      Now that I have made my final decision I can complete the wires that are going to the battery terminals.
      Fan Relay wires all wrapped & labeled in Tech Flex wire wrap.
      Playing with the wire routing to see if I like it.
      Trimming the weld stud.
      Hard to tell in this picture but if you look closely you can see I added a line clamp to secure the wire behind the battery tray.
      The fan relay trigger runs under the battery tray and I will connect it to the Holley ECU wires that are running on top of the inner fender.
      I am also looking at options for the Vintage Air Coolant & AC Line.
      Need a break from the car so I ran over to the Eastwood store and picked up some Flexible strip caulk that I am going to use on the back of the Bolt On DSE Firewall closeout panel.
      marty-mj
      Nov 2018
      Looks pretty good.
      2021 Durango R/T
      2005 Dakota beater
      2003 Dakota project-o-mobile
      Chicago
      Looks pretty good.
      Thank You I am sure having fun.
      marty-mj
      Chicago
      Shiftworks Shifter Cable & Detent thingy ( 02-17-22 )
      I needed a simple project as I didn't have much time to work on the car. So I decided I would install the shifter cable and the Detent piece.
      The 30'' cable seems very long. I am going call them to see if they have a 27" or 28" cable as I think the shorter cable will work better.
      marty-mj
      Chicago
      Plugging away at all the little things ( 03-03-22 )
      Man are these hard to find and I have five Autoparts stores within four miles of my house and the good news is I finally
      found them at Autozone. I needed one for the radiator and one for the over flow tank. I like these as I can attach a 3/8's hose
      so I can control where the coolant goes if I have to drain the radiator or overflow tank.
      Of course I couldn't get the old one out so a quick trip to my buddy Ben's house and the job of getting the old one out has begun.
      A couple wraps of "Oatey FASTape" to prevent the fitting from getting stuck again.
      Another Quick trip to Ace Hardware for some small hardware and of course I need some animal crackers
      Yes, another quick note.
      I use the "Pushnut" bolt retainers to hold the bolt to the tank which makes installing the tank much easier. I also installed
      a layer of cork on the tank bracket to protect the paint on the core support.
      Has anyone use one of these as I might try this so I can bleed the brakes by myself ?
      marty-mj
      Oct 2011
      I’ve used a similar tool to bleed brakes and clutch. Only difference I see is my tool had a vacuum gauge on it so I could actually see how much psi I was pulling. I also bought a fitting that went on the power steering reservoir cap so I vacuum bled the power steering system as well. Not that I needed to?? The thing that bothered me when bleeding brakes is that none of the fittings fit tight enough over the bleeder nut on the calipers but then again maybe I was pulling too much vacuum (15psi) so I would always get air bubble rushing in. After bleeding 3 bottles of brake fluid I just called it good. Tried the brakes and they felt great. Drove the car around the block a few times and they felt great. Never felt spongy, same with clutch.
      Chicago
      That is what I was hoping you would say as I would like to be able to bleed them by myself and not have to worry about always asking a friend to come over.
      Quote Originally Posted by Bugzilla View Post
      I have to ask, how many rolls of blue tape have you gone though so far? Haha
      Honestly I have no clue and I have wondered that myself many times if I had to guess I would say a minimum of 3 possible 4.
      This however deosn't count the two partial rolls I have in my toolbox.
      marty-mj
      Feb 2016
      SoCal
      1970 VW Bug - Just your average mid engine Bug
      Track toy - 06 Evo - E85 and lots of boost
      Newest track toy - 2021 Supra
      Oct 2011
      Btw don’t forget to bench bleed the master if it’s new
      Chicago
      The master isn't new and was on the car however it has been sitting for 3 years without any fluid.
      Do you think I should bench bleed it again as I never thought about that ?
      marty-mj
      Chicago
      G-Force Crossmember going back in. ( 03-05-22 )
      I needed to remove the G-Force Crossmember to slot the holes so the bolts would go in a little bit easier.
      Of course Remy was supervising the entire job until he saw a squirrel.
      I am happy we designed the exhaust so it could be easily removed.
      Remy is very happy with used the Lift-Jack to support the transmission.
      Noah Hard at Work
      Back to the Powder Coater to get recoated.
      Retraining the charge lead for the optima charge as it wants to go the opposite way. So I wrapped and zip-tied to so it would lose it's shipping memory.
      Now that I am 100% happy with the fuel line routing I going to tape the ends of the DEI heat sleeve.
      Yet another to do list.
      I decided I am going to use the stock Trans pan so I will be ordering ARP 6 Point hardware to match the rest of the hardware on the car.
      marty-mj
      Sep 2017
      I like the trans crossmember. I should have used one similar for more exhaust clearance. Looks like your steady chipping away at it Marty.
      TANKMASTERJ
      Jasons Toys
      2000 HD Softail
      Jun 2016
      Any update on this build?
      Jul 2021
      Quote Originally Posted by Toccoa View Post
      He has updated it quite thoroughly on Lateral-G under the same title.
      Chicago
      My goal is to start updating this thread over the weekend.
      marty-mj
      Chicago
      Vintage Air Hose Routing ( 03-06-22 )
      It's getting closer day by day by day.
      Today's project is to figure out how I plan to run the coolant and AC lines.
      Training this line so it lays better in the inner fender.
      Hiding the switch behind the battery.
      Plenty of clearance
      marty-mj
      Chicago
      Battery Wiring Clean Up ( 03-06-22 )
      Seriously I am getting really good at taking this car apart. Once again I am taking the positive off the mock up battery.
      I slipped over some heat shrink that I will eventually heat up once every thing is complete in this area. If all works out like I plan it may look really cool or it will be a total disaster.
      I need to lengthen the indicator wiring as I am routing them so they can't be seen through the grill. The good news I have extra wire so this will be a simple task.
      Animal crackers just because I was hungry and I found them in the cabinet.
      - - - Updated - - -
      Since they were wound up in a tight circle and I was tired of fighting them. I hung them and turned up my Forced Air Heater and warmed them up for a couple hours. The good news it worked and they un-curled quite nice.
      Since I am not painting the radiator for this version of the car. I decided I was going to smooth out these scratches.
      couples minutes later. Success !
      marty-mj
