    Page 43 of 48 FirstFirst ... 33 38 39 40 41 42 43 44 45 46 47 48 LastLast
    Results 841 to 860 of 949
    1. #841
      Chicago
      Intake Manifold Fittings ( 10-30-21 )
      Planning ahead before I run over to Ace Hardware for some fittings as the one's that are supplied are useless.
      So the Earl fitting that I happened to have looked like it was going to work. However, It did not as it hit the valley cover.
      So I found my Mike Norris Catch can and I used these fitting to start mocking up the fittings I needed.
      After a quick trip to Ace I think I have the fittings I need.
      Only at Ace can you find a 1/8" Hose Barb (trust me I looked everyone else)
      First Mock Up
      marty-mj
    2. #842
      Chicago
      Water Neck and Intake Manifold Plumbing ( 10-31-21 )
      I had time to do a couple simple projects so out to the garage I went.
      I decided to mock up some of the hoses.
      Thankfully the auto parts store is close
      Nope, I don't like the way this hose looks.
      I ordered this custom hose with all kinds of crazy bends in it.
      marty-mj
    3. #843
      Chicago
      Last one for the night Upgrading to a Waterproof Relay ( 10-31-22 )
      Way back somewhere in this thread I installed Painless fan relay and I screwed up and didn't order a standard fan relay. So I ordered a new Water Proof Fan Relay kit.
      Since it is in between the battery and the radiator the batter once again needs to come out.
      Thankfully I used a weather pack connector as I was able to just remove the ground from the plug.
      marty-mj
    4. #844
      Chicago
      Vacuum Hose Installed ( 11-09-21 )
      My molded hose arrived
      I also received another fitting for the Fuel Pressure Sensor
      Looks like I need a longer hose.
      Found an all in one fitting that will be replacing two of the fittings.
      marty-mj
    5. #845
      It looks like you got a lot of stuff figured out in the last few posts. That stuff can drive you crazy. It looks good.
    6. #846
      Chicago
      Optima Batter Charger Plug ( 11-09-21 )
      Since I keep the car on the optima charger when it is parked in the garage I decided to mock up the wire and see if I could hide it when it's not in use.
      I can easily tuck it in the frame rail when not in use.
      marty-mj
    7. #847
      Chicago
      Trunk Grounds Wires ( 11-12-22 )
      Today I will be working on all of the various ground wires.
      My goal is to make then looks nice and I even have some company in the garage today.
      Ground wire from the block to the frame
      Wires running back to the battery ( I think I have a cool idea and I hope to share it soon )
      Securing the ground wire to the motor mount bolt.
      I am finally connecting the wires from the relay to my gas tank.
      I also purchased this bad ass headlight switch from a gentleman on Facebook. I am going to have it anodized
      black so it blends in with the Covan dash insert.
      I have been looking for Intake Tube idea's and I think I found one that I love.
      - - - Updated - - -
      marty-mj
    8. #848
      Chicago
      Thank you and I am learning as I go and I am having fun while I am doing it.
      marty-mj
    9. #849
      Chicago
      Fuel Line Routing ( 11-14-21 )
      Another reminder while I am here to powder coat the spring pocket and the lower arms.
      The fuel lines runs right over the spring pocket and I am going to trim a little bit of it off to protect the fuel line.
      I started slowly removing just a little bit.
      Then I took just a little more off.
      Out comes them death wheel.
      A little clean up.
      All better now and I am still going to run the line through DEI ExoSleeve.
      marty-mj
    10. #850
      Chicago
      Kore3 FlexKORE Brake Line ( 11-14-21 )
      I am finally installing the FlexKore brake lines.
      Old lines are coming out.
      marty-mj
    11. #851
      Nov 2018
      Wow, you got a ton done.
      On the battery switch, only one is necessary but if you wanted two it wouldn't hurt anything. It would save having to re-run the positive wire since it looks like it would no longer reach the battery without the switch. But, I would run one on the negative side because ECMs are far more sensitive to having the plus side opened than anything else on the car would be.
      2021 Durango R/T
      2005 Dakota beater
      2003 Dakota project-o-mobile
    12. #852
      Chicago
      Thank you for the quick reply as I am not sure I have it in me to redo the battery wire again. However, I might have to redo the ground wire as it may be to long now.
      On a side note I still have about 20 more posts to do this week.
      marty-mj
    13. #853
      I'm looking forward to seeing them all.
    14. #854
      Chicago
      What should have been a simple project ( 11-14-21 )
      What should have been a simple pan swap turned out to be a no go.
      Since the current pan on the new transmission from Atomic was a standard depth I ordered a stock depth pan
      as I didn't want the pan to hang down and lower then it was. Well this one didn't works so I guess at some point
      I will order another one.
      Just in case anyone needs to know what size the bolt is.
      marty-mj
    15. #855
      Chicago
      Yes, I know this is overkill ( 11-14-21 )
      I think I am going to rename this car to Project Overkill
      Once again I am taking the passenger side header off so I can get to the wiring at the starter.
      So I dropped the lock washer of course my floor is speckled gray so it blended right in.
      Eventually I laid on the ground with the flashlight so I could find the freaking thing.
      marty-mj
    16. #856
      Chicago
      Wiring toolbox ( 11-14-21 )
      So the other day I was looking at all of the tools I have collected for wiring this car and I thought I would share pictures of my tool box that is completed dedicated to wiring. So when the car is done it will be going back to my warehouse.
      marty-mj
    17. #857
      Chicago
      Fuel Line Routing & DEI Heat Protection ( 11-20-21 )
      I need to widen this rectangular hole so the fuel line can pass through this opening safely.
      I installed the DEI Heat shield and EXO-Sleeve.
      I am still trying to figure out if I am going to secure the line to the firewall or just let it hang from the fuel rail. Which doesn't sound good as I type this.
      This is the final AN fitting that I need to finish the fuel line.
      marty-mj
    18. #858
      Chicago
      ARP Battery Bolts ( 11-25-21 )
      I am not a fan of battery bolts and I really like ARP bolts. Since Rad Rides uses them on their builds I might as well use them on my car.
      Apparently the bolt got a little warm.
      I ran the bolt all the way in to make sure it wasn't to long. Eventually I will order the correct bolt.
      marty-mj
    19. #859
      Jun 2016
      I think it’s Project Perfection. I’ve learned a lot watching this thread.
      That said, I think we would all love to hear that engine hum and exhaust rumble by February.
    20. #860
      Florida
      I think Overkill is the perfect name!
      Having failed tech inspection at a track once many years ago for a pressure regulator bolted to the firewall, I will mention that sanctioning bodies are picky about the possibility of fuel lines being cut by debris should something break through the bell housing from a clutch/convertor or whatever. So if you can keep your fuel lines out of the direct line of shrapnel in flight it'd be safer.
