    Page 40 of 48 FirstFirst ... 30 35 36 37 38 39 40 41 42 43 44 45 ... LastLast
    Results 781 to 800 of 949
    1. #781
      Chicago
      I'm in the same stage. Kw with wiring and where to put it. Slow and steady.
      Wish I would have run my LS harness through the middle of the firewall as you did. But it's too late for all that now.
      Yours is looking killer. And nice progress.
      And the grommet assortment, OMG I bought two different kits and still ordered several more off of McMaster Carr. I'm grommet poor lol.
      tankmasterj
      Hi Jason,
      I so with you on the grommets as I have purchased at least 3 different kits and 5 or 6 small bag assortments and a bunch from McMaster Carr. My only regret is that I didn't place mine lower on the firewall as it would hidden from site but a bitch to get at.
      I just looked through your thread and your car is amazing and I love the grille. I think your harness going across the lower part of the firewall will look good if use a nice stainless steel line clamp and use a couple of the bolts from your closeout panel to hang it. I have some really nice ones that are rubber coated & anodized black that would blend in nicely. Once the motor and trans are in your not going to see much of the harness.
      marty-mj
    2. #782
      Chicago
      Power & Ground into the Passenger Cowl ( 07-05-21 )
      I am running an additional power & ground on the passenger side of the car. In order to keep everything neat and tidy I am running the wires inside the Holley Power/Ground wire loom.
      In order to stabilize the wire loom I ran it through the grommet which I wrapped with Tessa Tape which was then covered with 3m Electrical tape to give it a finished look.
      I didn't want a power source in the cabin so I choose to move it into the cowl panel.
      Which should keep it out of harms way and still be easy to access.
      I used a couple more Weld Studs to mount the power stud.
      While the epoxy was curing I started working on the four optional wires that the Terminator X can trigger.
      My thought is it is much better to run it now then figure out how to do it later.
      I cut all four wire to an equal length and then installed a different color heat shrink on each wire end so I would know which one is which at a glance.
      I also labeled a couple more wires while I was there.
      There is a lot going on in this area and when it is finished will be easy to service. I hope !!!
      Since I have an early version of Holley Terminator X I have to trigger the transmission signal with a relay.
      More notes. This one is reminding me to replace the ground stud with a brass bolt.
      I am also working on a solution to keep the coil harness out of harms way and look nice.
      marty-mj
    3. #783
      Chicago
      Two Weeks Later... ( 07-14-21 )
      Being honest the weather was so perfect that I spend the last 10 days riding.
      I also purchased a nice small heat gun which only gets hot enough to shrink the heat shrink tubing.
      I finally started working on the ground stud.
      Picked up a couple more parts.
      I will be using this relay to trigger the fuel pump.
      marty-mj
    4. #784
      Chicago
      Playing with Radiator Hoses ( 07-18-21 )
      While I was at Good-Guys Columbus I ran into a gentleman that found an over the counter radiator hoses solution that may work in my car. I ordered them up to see how close they would be on my car and they look pretty good.
      The lower looks good but it will need a swivel neck for it to work correctly.
      marty-mj
    5. #785
      Chicago
      Playing with the Kick Panels ( 07-31-21 )
      Seriously, I forgot how nice these look.
      Plenty of room to seal off the cowl panel and install a set of shallow mount speakers.
      marty-mj
    6. #786
      Chicago
      All the little Stuff that you still have to do ( 07-31-21 )
      I wanted to start with an easy task so I labeled a few more wires under the dash.
      Then I moved onto the Holley Trans relay wiring.
      This will end up getting it's power from the power lug in the passenger side cowl panel.
      I can finally remove a Blue Tape Note.
      Just a couple wires on the new power lug.
      I still have to come back and make everything look pretty.
      marty-mj
    7. #787
      Chicago
      KD Hot Rods Radiator Hoses ( 07-31-21 )
      So Kenny built these awesome steel hoses that I will most likely use.
      However, when I had the Guys @ High Speed Welding redo the upper and lower water necks the upper is about a 1/2 inch to long.
      I will need to address this at some point.
      Lower hose just needs the Mr. Gasket swivel water neck and we are good to go.
      marty-mj
    8. #788
      Chicago
      More wiring and thank goodness for my blue tape notes ( 07-31-21 )
      Sometimes you just need to stand back and take a picture.
      I wanted to make sure all of my grounds had contact with bare metal.
      Now it does.
      I love my blue tape notes
      Calling it a night.
      marty-mj
    9. #789
      Sep 2017
      Dang your absolutely killing it on wiring. I'm about to be back on mine as soon as my daughters get a deer hopefully this weekend. Around here deer seasons stops everything lol.
      But yeah I'm going to use some billet clamps for all my wore looms and my heat and ac lines. Both will be wrapped in black nylon braid and clamped the same way.
      I know people normally try hiding it all bjt I'm going for neat and industrial look. Your car is bitchin keep it up.
      Jason
      Tankmasterj
      TANKMASTERJ
      Jasons Toys
      2000 HD Softail
    10. #790
      Chicago
      Jason
      Tankmasterj
      Thanks Jason, I am actually having fun and always looking for cool idea's and things that I could do better.
      Tell your daughter she better hurry up as we want to see more progress on Dad's car. I also agree with you on the hiding vs keeping things out so they are easy to service. I struggle with that as there is stuff that I want to hide and then there is stuff that I know I shouldn't hide. I will be going back to the drivers side coil harness and bringing the extra length of wire back into the car to keep it out of harms way.
      marty-mj
    11. #791
      Chicago
      Remember all those Yellow Wires ( 08-07-21 )
      So you remember all those yellow wires well they need to go somewhere.
      Which means I need to drill another hole in my freshly painted firewall.
      Just in case you someone else needs to do the same here is the grommet I used..
      If you have been following along I had a close call with the drill bit hitting the wire harness.
      So this time I removed the blue wire that is passing through the firewall.
      I connected two of the wires to the ECU as I will be using them to trigger the Fan and to turn off the A/C if it is running (still need help with this one).
      I also need to organize all the wire so they look nice even though no one other then you guys are going to seem them.
      1st Attempt
      marty-mj
    12. #792
      Chicago
      I am starting to like the aesthetics of the wiring harness ( 08-12-21 )
      Admitting you have is the first step and I have realized that I have a problem with the wiring.
      Which means I am going to keep playing with it till I get it to look the way I want it.
      Playing with the Injector Harness
      So I have a question for Holley. Why on Gods Green Earth does the Cylinder head ground wire need to be 18" long when it is only 4" away from the dang bolt they want you to connect it to. Then why would they give a ring terminal that is way to freaking big for the wire.
      Second complaint. Seriously these fitting would be nice great if you could actually use them. If you actually tried to connect a hose to them it wouldn't allow you to bolt the intake manifold to the heads as it holds the intake up 1" because they hit the valley cover.
      Playing with the injector harness
      Here we go again.
      huh I kinda like this.
      I installed 1/4" Tech Flex wrap since the 1/8" Split Loom wrap isn't available right now. But heck by the time I finish this car they might offer 1/16" wrap.
      marty-mj
    13. #793
      Chicago
      Holley Fuel Pump Relay ( 08-17-21 )
      I am installing a relay in the trunk for the Holley In-Tank pump. I decided to purchased
      an extra relay that I will keep in the car just have a back up for road trips.
      Remember my complaint about needing a ring terminal for the Cylinder Head Ground wires. I finally
      found someone that had them in stock and it wasn't Amazon It was Ebay. I have extra's if anyone needs a set.
      While I was searching Ebay I accidently found this.
      Danger Will Robinson !!!!
      Ugh !!!
      marty-mj
    14. #794
      Chicago
      Holley Fuel Pump Relay ( 09-05-21 )
      Took two weeks off from the car due to family life. But now I am back at it after work and riding.
      I have some company in the garage with me today. However who new it was nap time.
      Trying to fund a good location for the fuel pump relay.
      Since the car is already painted I once again used a Weld Stud.
      Yep, it's messy looking but one I spray in the bed liner coating you will never notice.
      More wiring.
      I had to extend the fuel sending unit wire.
      There is now way this was a good ground.
      More notes
      I will be back tomorrow one the Epoxy dries.
      marty-mj
    15. #795
      Chicago
      Fuel Pump Relay Final Wiring ( 09-06-21 )
      Once again I labeled all of the wires.
      Sending unit wire
      Wrapped with Tech-Flex Wire Loom. (09-08-21 )
      I am struggling with running the wires on top of the tank. I just don't fell like it is safe as the floor pan has been Rhino-Lined and it just seems like the wire are being crushed.
      Time to come up with a new way to route the wires.
      marty-mj
    16. #796
      Chicago
      Since Holley wants this wire grounded to the back of the cylinder head. Why would it be so freaking long when it literally is only inches away from the bolt that it needs to go to.
      Yep, I over stripped the wire.
      I did a better job stripping the wire on the passenger side.
      Well, Remy fell asleep as it was a beautiful day.
      Ran the last couple grounds to the brass bolt that is grounded directly to the battery.
      marty-mj
    17. #797
      Chicago
      Fuel Pump & Sending Unit Wiring ( 09-20-21 )
      So I went back out to the garage after talking with a few guys about how they wired there in-tank pump and I decided to try what they have done.
      I individually wrapped each wire in Tech Flex Sleeving to protect the wires from abrasion.
      It's definitely better so I am going to sleep on it and see how I feel in the morning.
      I also ran the sending unit wire next to the power & ground.
      marty-mj
    18. #798
      Chicago
      Fuel Pump & Sending Unit Wiring Continued ( 09-21-21 )
      Back to Plan "B" or is it Plan "C"
      I plan to run the wires around the tank and secure them with the "Weld Studs" in multiple locations.
      While I was at Sema I found the originator of the Studs and wow do they have some cool options.
      marty-mj
    19. #799
      Aug 2002
      Sweden
      Country Flag: Sweden
      so... have the doctors found out what diagnose you suffer from yet?
      If it's contagious, because then maybe I can stay with you for a while?
      Great build here! what an attention to detail! I love it!
    20. #800
      Oct 2011
      Why don’t you run the wires through the groove in the tank?
