    Results 1 to 13 of 13
      Oct 2008
      De
      One wire Alternator
      What needs to be done to convert to one wire alt. Currently have the original on my 69 chevelle with the seperate regulator.
      Orlando, Fl
      Quote Originally Posted by Fast Willy View Post
      You do not want a one wire alternator. You are much better with a three wire internally regulated unit. Do a search for CS130 conversions. Off the shelf GM reliability with plenty of oomph. A small harness is needed to convert from an SI series alternator to a CS.
      Nick DiPrenda
      Feb 2010
      Second the three-wire setup. See this page for more info.
      Nick
      '72 Monte Carlo
      Build Thread
      Fontana, CA
      I have had the OG, 1 wire and now run a 3 wire system courtesy of madelectrical. Best choice ever. I did mine when the SI conversion was most popular. I have done CS as well for friends and when I ever blow an alt I will change over to the CS 3 wire setup.
      Save yourself the headache and do not buy a 1 wire alt.
      Nick R.
      Lawrenceburg, TN
      I see a bunch of people saying don't do it?? but why?? just curious?
      So. Cal.
      I dont get it. I changed my system to a one wire alt and dont have ANY issues. I read the MAD info from the link. They didnt talk about much cept that you can have an idiot light. They said the one wire alts weren't readily available from main stream auto parts store, thats BS.
      You can use a volt guage or amp guage with a one wire alt just fine. You want a dummy light to tell you when things are bad, yup, you can have that too. I think the link to the MAD site is bad info.
      I still dont see ANY real info why a one wire alt is a bad thing. I do see ALOT of good info on why they are used though. JR
      What I write is opinion, none of it is factual. 2010
      Even though I'm conscious it doesn't mean I'm coherent. 2011
      I'm getting better with age. Best thing about old age is I don't know any better. 2012
      Jul 2010
      Sacramento, CA
      Quote Originally Posted by JRouche View Post
      reasons they are bad:
      Poor output at low RPM's
      VERY Poor voltage regulation
      Poor availability
      More expensive than a simmiler output 3 wire
      Reasons they are good:
      Easy to install.
      Dont be lazy, dont waste your money, get a 3 wire. I ran a Pep Boys that had 475,000-515,000 parts and not one of them was a 1 wire alternator. We had 20-30 CS and SI alternators though.
      -James
      1974 Z28 SCCA C Prepared
      1990 Firebird NASA CMC
      1989 Civic Si SCCA STC
      Lawrenceburg, TN
      Quote Originally Posted by SLO_Z28 View Post
      Poor availability
      Poor output at low RPM's- 1 wire alts require the RPM to reach 1400 to begin proper charge that's were the ignite switching level on most are set - and once 1400 is reached they continue to charge till ignition is turn off and cycle starts again
      VERY Poor voltage regulation- that's usually a poor engine ground, that symptom often doesn't show with a multi wire set up because there is a alternate ground in the 3 multi wires (field wire, stator wire, ground wire)
      Poor availability- ?? our local pep boys has them, so does O'rielys, and we carry them from power master in their white box series in chrome for as little as 70 bucks (and that's a chrome name brand?
      I'm not for them or against, I just want a reason for the negative opinions?
      I saw the same thing about a cylinder head company where everyone bashed them so I had a set sent to the shop and put on my 383, after install I made over 400 plus HP, and have now run them for 3 years at SCCA and autocross events without a problem, there was even a write up in car craft (that the new little company made good cylinder heads), and the guy that bashed the company was a mechanic for 20 some years (so he claimed)
      NJ
      If you underdrive the pulley it will not charge at idle. The one wire I have charged at 15 volts. A little too high for me, that's why I put the larger puller on it. I want to change it to 3 wire, can I change the regulator?
      Feb 2009
      muggy midwest
      Willy...the 3-wire alt. have regulator that maintain system voltage at all times by "sensing" any drop in voltage by an increase demand in amperage draw via an accessory being turned on. When amperage demand goes up, system voltage goes down. As voltgae increases amperage requirements for any given accessory goes down (to a point). So, you need a regulator that can stabilize the system under all conditions. A 1-wire is RPM based in terms of amperage output. One problem is they can't maintain system voltage when amperage requirements is higher than they can put out @ low RPMs. Say you are getting 60 amps @idle from your 1-wire-but you have the AC on, electric fan running, HO headlights on, stereo blasting, etc. and you are using 60-70 amps. Your alternator will not "put out" any more amperage because it cannot stabilize voltage-instead, voltage proportionately decreases as amperage demands goes up. Now your battery has to act as a buffer...but at the risk of not charging much. For short periods of time, this works-but is not ideal, thus the drawback of a 1-wire on a vehicle that sees a lot of low speed driving with a lot of electrical devices. Most people with 1-wires don't think they have a problem because at leats for a short while the battery buffers the voltage loss. I deal with a lot of electrical issues and I have a solution for you for your exact situation. I have an SI alternator that is 105 amps and is a direct swap for yours and I can explain what you need to do to modify your existing wiring for an internally regulated alt. by simply using the wiring you currently have. Pm me for a diagram...might be easier to walk you thorugh it over the phone-let me know.
      "...if at first you don't succeed, try again.
      If you still don't succeed, then quit-no sense being a damn fool about it..."
      -W.C. Fields
      HARNESSWORX
      (formerly gmachinz)
      Dec 2007
      Carlsbad, Ca
      some powermaster 1 wires can be converted back by pulling out a small plug on the side and inserting a 3 wire harness. mine however needs to be sent back, but they said 30 plus shipping. since i tore it apart to base and clear it, 30 will get me a 3 wire and the absolute confidence knowing that it was reassebled correctly (not that i doubt myself that much).
      Tim
      Build Thread Link
      Ramona, Ca. San Diego area
      Not to hijack this thread but...
      I was wondering about this for sometime. I have a carbed LS engine so I don't use the LS wiring harness. So what would be my best option for an alternator since I am going to use the stock camaro wiring harness?
      67 Camaro convertible (Jinx)
      Southern Indiana
      I use CSI 130 and CSI144 alternators, the idiot light wire from dash to the regulator, so to keep it and just jump inside over to one of the wires to the stock wiring. or you can simply reroute that one to the alternator key on. Ill try to post up the diagram in a little while.
      I have the numbers at home for the alternators I use in converting, swap out the heavy charge wire for at least 8ga I use 12 to 10 ga fuselink in this wire, crimp and solder all connections and rune it to same point.
      There is one wire I loop over to the battery terminal and then one from the idiot light wire.
      I need to look up the diagrams again I just unloaded some stuff from my computer but have it on disc at home.
      My email is [email protected] shoot me an email and stay away from one wire alternators, they cause nothing but headaches.
      Lee Abel
      AFTERMARKET PERFORMANCE
