      Aug 2002
      1965 buick riviera 4 wheel disc
      i am looking for 4 wheel disc brake conversion kit for a 1965 buick riviera. any help would be apperciated.
      Ive seen some front kits based on stock parts but nothing good for the back or a whole 4 wheel
      kit
      Oregon
      What are you running with respect to wheel size? We've done C5/C6-based brakes for a few 65 BOP applications and while there's more variations from model to model and year to year than we like, with a little bit of info from you we could probably confirm whether or not we have kits for it.
      Tobin
      KORE3
      It's what I does.
      Planning on wheels in the 17-18 inch range...haven't picked them out. Do ya have anything that might work?
      Oregon
      Quote Originally Posted by amcya View Post
      Any C5/C6 based kit will require at least 17's to clear the calipers. The larger kits, C6 Z51 and C6 Z06, will require at least 18's. The design of the wheel center and hoop will determine fitment. As I said before, we've done a few of these BOP applications already, it just seems like each and every one has been a little different from the last.
      Tobin
      KORE3
      It's what I does.
      Don't forget the 65 Riviera has a 5x5" bolt pattern. If you plan on using the corvette discs, you are going to have to change the bolt pattern.
      May 2002
      Northern California
      and a large hub hole.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
