    Results 1 to 20 of 22
      Netherlands
      Mij new braking System
      Look at that puppy!!. Custom build on aplication No of the shelf stuf..
      Uploaded with ImageShack.us
      Feb 2007
      Vancouver, WA
      san diego
      Nice looking caliper. What is the rotor size?
      Netherlands
      13 inch in the frond 12.19 in the rear fitting in 16 inch Bogard racing wheels ( if i ever get them lol)..
      san diego
      David,
      Any reason you did not go with a 6 piston?
      Netherlands
      PSA
      Piston Surface Area (PSA)
      What do you want? 4 Piston, 6 Piston, 8 Piston, 12 Piston. Whay so many? Is more better? Does the number of pistons make the caliper clamp more on the rotor? Let's clarify piston questions right now. It's simple and without question. Clamping force is line pressure times piston surface area.
      In a given location, you cannot put 6 pistons with the same surface area as four pistons. The six pistons will always be smaller in overall surface area. Also, some manufacturers would have you believe that six pistons spread the force more evenly over the back of the pad. However, even if they did gain here, (which they don't), the resultant weaker caliper as a result of placing a piston in the key stress area of the caliper, creates a far weaker caliper.
      Use the formula below to calculate your Total Clamping Force (TCF).
      CLAMPING FORCE = PISTON SURFACE AREA (ONE SIDE OF ROTOR) x LINE PRESSURE
      See the chart below to calculate your Total Clamping Force (TCF) from your caliper.
      Diameter of Piston Radius (equals 1/2 diameter)
      R2 Piston Surface Area
      (radius squared x PI)
      0.50000 0.25000 0.06250 0.19635
      0.62500 0.31250 0.09766 0.30680
      0.68750 0.34375 0.11816 0.37122
      0.75000 0.37500 0.14063 0.44179
      0.81250 0.40625 0.16504 0.51849
      0.87500 0.43750 0.19141 0.60132
      0.93750 0.46875 0.21973 0.69029
      1.00000 0.50000 0.25000 0.78540
      1.06250 0.53125 0.28223 0.88664
      1.12500 0.56250 0.31641 0.99402
      1.18750 0.59375 0.35254 1.10753
      1.25000 0.62500 0.39063 1.22718
      1.31250 0.65625 0.43066 1.35297
      1.37500 0.68750 0.47266 1.48489
      1.43750 0.71875 0.51660 1.62295
      1.50000 0.75000 0.56250 1.76714
      1.56250 0.78125 0.61035 1.91747
      1.62500 0.81250 0.66016 2.07394
      1.75000 0.87500 0.76563 2.40528
      1.81250 0.90625 0.82129 2.58015
      1.87500 0.93750 0.87891 2.76116
      1.93750 0.96875 0.93848 2.94831
      2.00000 1.00000 1.00000 3.14159
      2.12500 1.06250 1.12891 3.54656
      Auburn, WA
      Quote Originally Posted by Roadrage David View Post
      I actually thought that was an industry-wide known fact, not some marketing consipiracy. Who's the manufacturer?
      Matt Jones
      Mechanical Engineer
      Art Morrison Enterprises
      Netherlands
      http://www.thebrakeman.com/home I so totaly Dig there Filosefy and there aprotch about break systems. check tech page. and go tru these individual pages!!. to me it makes total sense. There F5 caliper in a one to one Dynotest with the brembo 6 piston mono block spankt brembo,s butt. here is clip from Ernest Rocco SCCA road race champion and Time atack champion http://www.youtube.com/watch?v=zpBPopHUe68 http://www.youtube.com/watch?v=OrTxTRr5Z2E i belive 6 out of the top 10 of the drivers in the road race champion ship drive around with Brakeman brakes..
      Netherlands
      PS afther a serius discussion about brake systems Savittske Classic and custom( http://www.scandc.com/index.htm ) pointed me out to them some time ago!!!!.
      we all know he thusend fool around when it comes to suspention and racing . iven tho hes not selling the stuf he told me to chek them out .
      Witch i did , and like i said befor, going tru there company filosefi, it makes total sens!!!! why they only use a 4 piston caliper.
      Dec 2008
      Covina, Ca
      When it is time for brakes The Brake Man is where I am going. They make there calipers with the biggest piston area (if needed), I have heard that the pads and rotors last a very long time compared to others, and show virtually no signs of pad taper.
      Jon
      Netherlands
      Finaly a beliver Hhahahahahhaha. yes Ernesto Rocco(chek video above) only used 2 sets of rotors in 10 years time. up frond and the rear hasend come of yet. Also 10 years with the same calipers...Brakeman brakes build a compact system with incredibel torqu out put, also in my set up no cross drilled ore slouchted rotors. Just sanding with 80 grit afther a couple of races wil clear the glasing..
      cant belive people dont pick up on this, and not seing this brand of super brakes mentiond on this forum..
      Dec 2008
      Covina, Ca
      Finally, lol. What car and suspension set up are you running?
      I in the middle of building a 69 Javelin with c6 subframe Scott Mock built for me and a 3 link with a floater in the rear. I will also be going with non slotted/drilled rotors. Currently on the rear I have a set of wilwood 4 piston forged superlites with the 12.19x 1.25 GT slotted rotor, as soon as the rotor and pads go I will swap them with the brakeman's rotors and pads. Whats nice is when ever I want to get rid of the superlites I can buy a set of the F3 calipers and they will bolt on to my current brackets.
      Jon
      Netherlands
      Jon car is a 68 firebird heavely custom build 27x16x13 tire rim combo in the rear 25x16x11 in the front.
      Modified BMR torque arm suspention Afco Elite coil over shocks Frond and rear.
      Il get the F4 Tornado Calipers alround!!! with 13 and 12.19 inch rotors. car wil be 3 to 3 1/2 inches of the ground..
      Custom brakets where made bij them to fit the ATS afx Tall spindels .
      Have speed tech arms but going to replace the uppers with SPC arms.
      Drove around with the SSBC Force 10 calipers for 4000 miles. and they are ok for the streets and a 30 min track run.
      They where good, but pads wore out not evenly.
      Sins i was stepping up in performance and was going to runn a smaller rim Savittske Classic and custom pointed me out to them .
      And as you know you wil not find more info on brakes anywhere els but on there site.. and as said eurlier i cant belive i havend seen people here useing them its always Wilwood/ ssbc/ bear .
      A frind of mine who hase about 8 race cars and a race team including 2 Ferraris/1 pratt and miller corvette(le mans),4 Omega V8 stars,1 Mosler ecetera. are running these big 6 piston AP racing brakes. I was stunned wat kind of drag these brakes have!! the rotors dont run free !!!. il bet they loose 10 hp on every wheel on EVERY CAR.. The 14 inch rotors are replaced every couple of races ""they are CRACKT"".
      Here is where Brake man brakes shine and have there patern.s work for them.
      They last forever and dont drag. and piston clamping and releasing is super fast. and more compackt systems.
      Dec 2008
      Covina, Ca
      Are you getting there Storm rotors or the expensive Hurricane rotors?
      Jon
      Netherlands
      Jon im getting The Storm rotors/system. http://www.thebrakeman.com/scca___nasa
      The Hurricane Rotors are way overkill, and indeed cost about 1200usd a piece!!.
      they are heavy tho as they are made out of Steel
      insted of being casted. I do like there cooling aplication tho..
      Dec 2008
      Covina, Ca
      Cool, sounds basically like the same kit I will be getting except for a 14" rotor on the front.
      Do you have any pictures of your car? It sounds like a really cool project.
      Jon
      Netherlands
      jon end of jan i wil post the first pictures beacuse right nou there is not a lot to show.... thos 14"" are going to look cool in a 17 inch rim
      Netherlands
      Anybody heard of Hurst/Airheart and JFZ brakes from the past !!??...
      Netherlands
      Nobody!!!. comon we must have a couple of vintage racers here......
      Feb 2008
      Denver NC
      I have had the Displeasure of working on JFZ Junk...A friend of mine is building a Watson Roadster thats equipped with Hurst/Airhearts.... they are getting hard to find... Racing brake componets are designed to wear Surface cracks or heat checking are normal..Rule of thumb I go buy.... Brembo and AP Are good enough to win in F1.... NASCAR and pretty much every form of professional motorsports... where brakes matter... cost is no object and there are no limitations on brands.
