      Jun 2006
      Katy,TX
      Switching out DOT 5 silicone fluid
      OK guys a racer buddy wants to swap out the DOT5 silicone for a glycol based fluid to see if it firms up his pedal. Procedure? Drain really well MC and calipers, blow out lines then pressure bleed some gycol based fluids first before fill the system with it?
      I think that's the minimum. I'd go so far as to rebuild the calipers and master cylinder and replace all the seals.
      jp
      ​John Parsons
      Mantorville, MN
      I drained and blew out the DOT5, then flushed with air brake antifreeze (alcohol), drained it and blew it out again, and then flushed again w/ DOT4.
      It's been 5 years, trouble-free (I flush w/ new DOT4 every spring though)
      Derek Kiefer,
      Mantorville, MN
      May 2001
      Mesa, Az.
      This is good to know. We have a couple vehicles with DOT 5 that I wish had DOT 4
      Phillip
      Jul 2007
      Calgary, Canada
      Yes I also have to fess up I fell victim to the Dot 5 hype years ago and need to replace it out of one of my rides.
      Dave
      68 Corvair coupe
      65 Impala SS
      64 Corvair Rampside
      62 Corvair Greenbrier
      Asst. daily drivers
      http://www.sourceboards.com/
