Results 1 to 20 of 25
12-04-2010 #1
Mustang II MII spindle brake combinations
What spindle/brake combinations are available for the Mustang II, MII, based front suspensions? Specifically for my situation I’m looking for a brake set up for my 67 Mustang that has a Rod & Custom MII coil-over front suspension. The car came with the MII already installed so my goal is to improve its’ performance/geometry by minor modifications and bolt on changes for mostly street use and occasional track appearances. I have 17x8 (48mm/1.9” offset) O.Z. Ultraleggera wheels with 245/40ZR17 tires up front. I would like 13” brakes, 2 or 4 piston, and I’ve looked at Wilwood, Baer, Brembo, and the Mustang Cobra PBR. I want to have a 2” drop or equivalent on the spindle but I also want improved performance, geometry, quality. I realize the suspension is derived from the MII spindle, so changing the spindle will probably require other changes to the setup. The Wilwood Pro spindle claims to be an improved MII design by being 1/2" taller reducing roll center migration. I am trying find out if Heidt’s Superide spindle or TCI’s Custom IFS spindles have improved geometry and could be used. I don’t know if there are any other improved MII spindles out there or if I should just use a standard forged MII 2” drop spindle. I am also interested in adjustable or longer upper control arms, lengthening the adjuster slots, or any other modest modifications that may improve the existing MII based suspension.
These are the combinations I have found so far:
MII forged 2” Drop Spindle ($230) w/ 13” Cobra PBR 2 piston ($500 + custom bracket MustangSteve $240)
MII forged 2” Drop Spindle ($230) w/ 13” Brembo Cobra R 4 piston ($1,200 + bracket MustangSteve $240)
MII forged 2” Drop Spindle ($230) w/ 13” Baer Track-4 4 piston ($1,350)
MII forged 2” Drop Spindle ($230) w/ 12.19” Wilwood Dynalite 4 piston ($760)
Wilwood Pro Spindle ($325) w/ 13” Wilwood SL6 6 Piston ($1,700)
Wilwood Pro Spindle ($325) w/ 13” Baer Track-4 4 piston ($1,350)
It looks to me like my best options are the following based on my goals:
Drop Spindle w/ 13” Cobra PBR 2 Piston for $970.
Drop Spindle w/ 12.19” Wilwood Dynalite 4 piston for $990
Wilwood Pro Spindle w/ 13” Baer Track-4 4 piston for $1,675
Does a 13” 2 Piston perform better than a 12.19” 4 Piston?
I’m thinking parts will be easier to obtain for the Cobra brake since it’s Mustang OE?
Is the modified Wilwood Spindle w/ 13” 4 piston brakes worth the extra $700?
Any recommendations for one of these or another spindle/brake set up in this situation would be appreciated?
