    Results 1 to 20 of 40
      Aug 2005
      Hamilton, NJ
      I love my DCC controller - using 4th gen fans, damn thing is great. I never hear my fans running and one of them has a growl at full voltage. It did when I put them in 4 years ago and I expected to have to change it. Not yet. If I did not have that I'd have run 3 relays and run them both at 6v at a lower temp and both at 12 volts if it got warmer or AC came on. That is how GM wired the later 4th gens. I’m no engineer, so I figure if GM decided they needed that extra ‘complication’ there must be a reason. Down side is you need 2 fan switches to do that w/o a controller. There is a thread at nastyZ about a dual temp BMW switch that is perfect for it.
      I had the exact same issue in my Z with the temps. It would run 150* or less on the highway and perfect 185* at idle/local. Stat was hanging open, and it was a relatively new (~2 years) Robert Shaw type. new stat fixed the issue. Same issue with my DD olds just this fall. New stat problem solved. Just throwing that out there.
      Scott from NJ.
      Vent Windows Forever! ...
