      Nov 2010
      slightly off the driven path
      MustangII clip/Big brake ?'s
      Hey Everyone, i did a search but had no luck...
      i have a MustangII clip on my '64 ChevyII and am interested in an LS or C4/5 type brake conversion... can anyone help me with bracket & hub etc parts list.
      thanks!
      edit
      i've found this Cobra 13" kit but prefer a GM set up.
      http://www.mustangsteve.com/cobrabrakes.html
      So. Cal.
      I know you are looking for a GM setup. But... I looked high and low. I saw alot of promising brakes till I looked at the prints for the calipers and fitment. All of them that I saw had the caliper hitting my wheel. I have a small wheel (17") and needed a zero offset because I already had my wheels/tires and they were pretty tight already on my 62 Nova.
      All of the GM calipers were pretty large and I had to go with wilwood. The cost was only about 100-125 dollars higher. And I looked at all of the possibilities. Going with Fords 13" brakes, GMs 13" brakes. Everything. And cost was a big consideration, but fitment was more important (of course). I ended up going with some wilwood brakes. And let me say, the car stops on a dime. And I have the rear brakes essentially "turned off" right now with the adjustable proportioning valve. Im still working on other parts of the car and havent had the time to dial in the rear disc brakes yet. So Im stopping on just the fronts. Alot of "modulation" or feel and I can put the WHOA on in a second. Its like dropping an anchor if I need it. Even from high speeds, no brake fade. And the pads are the inexpensive pads they toss in with the package, not even the good pads.
      Dunno, I like the idea of going with some GM brakes. Alot to be said for the brakes. But the calipers are really big. Didnt fit into my lil package.
      I like my wilwoods so far. I can tool around town at slow speeds and its like driving my honda, predictable and smooth. Then when Im at speed and need to put it all to a stop they clamp down pretty aggressively and put a stop to my madness. So well I might forget to turn on the rear brakes. Note to myself, adjust the rear brakes so they take some of the load. LOL JR
      What I write is opinion, none of it is factual. 2010
      Even though I'm conscious it doesn't mean I'm coherent. 2011
      I'm getting better with age. Best thing about old age is I don't know any better. 2012
      Nov 2010
      the LS on the rear should be easy. it's the MustangII up front.
      any sources on a PBR C15 caliper? i seem to see them around with different manufacturers name on them but i can't seem to find calipers alone, or even application info. i recently e mailed PBR, no reply as of yet.
      Wilwood, Baer etc i'd love to have but if possible i'd like to do this with a factory style part.
      thanks.
      Oregon
      There are a lot of different designs of MII spindles ranging from stock-ish to full aftermarket, so which one are you using? Std height or drop?
      Tobin
      KORE3
      It's what I does.
      Nov 2010
      it's a Heidt's 2" drop spindle...
      thanks
      i know nuh-think !!!
      Oregon
      These Heidt's MII drop spindles? If so, I believe we have C5/C6-based kits compatible with that spindle...like I said, there are a lot of subtle and not-so-subtle variations when it comes to MII spindles. The beauty of the C5/C6 kits is that you several options ranging from the base level C5/C6 to the C6 Z51, C6 Z06 and even C6 ZR1 carbon/ceramics if you dare, all with the same conversion brackets and hubs.
      Tobin
      KORE3
      It's what I does.
      Nov 2010
      well, i got impatient... thought there'd be a bit more participation regarding my question but what can i say...
      i pulled the trigger and bought this kit from Classic Performance Products
      52mm PBR C15 calipers, etc... $800.00
