    Results 1 to 12 of 12
      Jul 2007
      Olathe, KS
      AAW Classic Update or Highway 22?
      I'm currently trying to decide what harness to use on my '68 Camaro build. I'll be integrating in bits and pieces of the harness from the 2002 TA donor that I used. In addition to the PCM and harness, I'll be using the steering column (with ignition switch, wiper and turn signals) and BCM (for control of power windows, locks, interior lighting, and the basis of a few theft deterrents).
      Couple that with a custom gauge cluster, basic aftermarket stereo, Vintage Air setup, and aftermarket headlights/taillights and it seems I'll be using more non-traditional components than portions of the traditional OEM harness.
      That makes me lean toward the highway 22 harness. On the other hand, I'm sure the install will be a little more involved since it's not chassis specific and I'm not aware of a source for all the lighting sockets and connectors that I'll need to interface with the stock '68 components. It doesn't matter to me whether or not I use the stock fuse box bulkhead. I don't intend on overly smoothing the firewall, but I'm also not opposed to moving it if the opportunity arose.
      Knowing my setup, what would you choose? I'm trying to make a decision in time to take advantage of AAW's 12% off sale ending tuesday. Any help with that would be appreciated.
      Thanks in advance!
