Results 1 to 13 of 13
11-24-2010 #1
how much clearance should i have between the caliper and rotor face.
I will be thinking about this for the rest of the weekend till I hear back from gateway OR baer. I have a set of the Track 4 calipers and with the rotors and calipers mounted I have .45mm of clearance on the front face and 1.75mm on the back face.(sorry for using metric but these are the only feeler gauges i had at the moment). I looked and there is no way to shim the caliper to center it. matter a fact if i shim it it would make the front clearance problem worse. the rotors sent in the kit measure out at 1.105" thick. the slot on the caliper measures 1.189" which only leaves me .084" of clearance with only a little in the front and more in the back.
Ive never had a set of baer brakes before but in general i know that disc brakes tend to have or end up with a little bit of wobble.my concern is not enough clearance and once it comes just a tad out of true this may start hitting the caliper. since these are a "fixed" design as opposed to "floating" i have to make sure its all correct.
so my question is whats the deal? are these rotors so thick that they are not suppose to warp or just come out of true just a little bit? I took some pics they aren't the greatest but hopefully it will help. thanks in advance!
* will have the pics posted up as soon as they upload
