Results 1 to 12 of 12
- Nov 2007
- Golden, CO
- 85
Leaf Perch Pad - Above or Below Spring?
In the shop now, installing new leafs. This axle has muli-leaf perches. Each perch can be filled perfectly with the spring and one urethane perch pad.
Question:
Does the pad go above the spring - between the axle perch and spring?
OR
Does the pad go below the spring - between the spring and the shock plate?
This might be a no brainer but I'm getting different answers from good sources.
Mr. Pozzi says below spring.
Tech at GW says above spring.
11-15-2010 #2I've tried all three ways and the best is NO pad. Axle perch to leaf to shock plate.
Dan
1969 Chevrolet Camaro
/DSE/SDPC-LS7/T-56/FORGELINE/BAER/VAPORWORX/SPEARTECH
/DAKOTA-DIGITAL/RECARO/MOMO
/MSP-FAB/BLACKTECH/
11-16-2010 #3
- Nov 2007
- Golden, CO
- 85
Thanks for the advice Dan. That's great you have tried all three ways! I'll take your advice. BTW these are GW L-2 leaf springs. I'll put the spring right up on the axle perch then. Is there any reason not to use a 1/2" lowering block as a solid spacer between the spring and the shock plate? I was thinking of how I could make a solid spacer, but then I thought: wouldn't it be easier to buy one already made (and cheap)? I'm not looking to lower the car. With 2" drop leafs and the Herb Adams Mod, it doesn't need to go lower.
11-16-2010 #4
- Mar 2010
- AZ
- 801
