    Results 1 to 12 of 12
      Nov 2010
      MNG's new 68 GTO
      Well I finally got to meet up with that guy in Longmont with the 68 and I bought it!!!
      Thats the only pic I have I will get some more tomorrow depending on work....
      The good:
      Only real rust I saw was in the trunk floor
      Newer paint not show quality but a solid 20 footer
      New tires, alt, battery
      New seat covers, carpet, front and rear door panels, and head liner
      Hurst dual gate shifter!!
      New dual exhaust with "turbo mufflers"
      Good enough mechanical condtion I drove it home about 150 miles with no problems
      The bad:
      Cracked paint on the front bumper (they are made out of rubber and I don't think they used a flex additive)
      Speedo is a little jumpy at slower speeds
      Tach needs hooked up
      Gas gauge doesn't work
      Dash lights don't work
      Cigarette lighter doesn't work
      Radio doesn't work
      One of the wheel cylenders leaks
      Hide away head lights need repaired or you can just flip them by hand.... and save your self a bunch of
      Probably more that I can't think of or haven't found.... But for the price I can't bitch and I talked him down a 1000 bucks to a total of 10.5k!!!
      I want the car to handle well, corner flat, stop well, be reliable, and make about 400 whp so I can drive it across the country if I want to!! I don't plan to auto-x it, the only track time it will see would be drag.
      The plan:
      Whole new suspension A arms ?, bushings, sway bars, tie rod end links, whole new rear, etc....
      Disc brakes all around!!!! (it is drums all around and kinda sucks)
      Fix the little electical problems
      New radio
      Wheels to fit over the new brakes
      Fix rust
      Start saving for a LS based power plant....
