    Results 1 to 9 of 9
      Scottsdale, AZ
      64 chevelle air bags question..
      Hey all, forgive me as I searched through some current threads checking to see if I could find my answer and I was not successful. Please also bear with me as I am not as technically advanced as many memebrs I am sure.
      I have a 1964 chevelle SS clone with what looks to be the factory suspension - factory spindles, springs sway bars etc on front and chevy 4 link in the rear.
      Wheels/tires: I am looking at 18x8's in the front and 20x10's in rear
      My question is I have been looking over my options for air bags and was wondering if it is possible since I already have a 4 link rear end to simply put air bags in place of the springs that are there now with something like this (front and rear): http://www.opgi.com/product.asp?topc...3065&prodcode=
      So in other words... although it would be ideal, is it necessary to replace all bushings, upper/lower control arms, sway bars etc or did air ride really make a direct bolt on kit that will essentially achieve the ride height I am looking for without spending $5k and replacing the entire suspension?
      I realize it's a somewhat a vague question but if anyone can lead me in the direction it would be appreciated. Thanks
      Robbie
      1964 Chevelle
      396/TH350
      May 2001
      Mesa, Az.
      Robbie,
      The product in the link that you showed is Ride Tech (formerly air ride) stuff. Yes it will work just fine. You ask whether it will achieve the ride height you want but that is hard to tell. What ride height are you looking for? I will tell you that it will be tough to get a super low rideheight in the rear with the 20s. Most 20" wheels run tires taller than 27". Because of the taller tire you have to lower the car further to get the right look. Thus taking away from your bump travel. So I guess you have to ask your self, what rideheight are you looking for?
      Below is a picture of our 65 Olds hammered out on bags. I am using a similar bag in the rear to what you showed. These are Slam Specialties RE-6's. This is all the way down. Ride height is about 3" up from this. Please bear in mind that the back of this car is completely redone. With a 2.5" C notch and complete tunnel refabrication. So it takes quite a bit of work to get here... But that is the reason for the previous question. What kind of height are you looking for...
      Phillip
      Des Moines, IA
      Here's our page for A-Body parts:
      http://www.ridetech.com/store/muscle...tures_hash=V40
      Just a note: we use a rolling sleeve air spring on the rear opposed to a double convoluted. The rolling sleeve has a more linear spring rate and as such provides a better ride quality.
      Scottsdale, AZ
      Thanks for the replies...
      Phillip, to answer your question... yes. I want my car to look like your Olds. or like this http://www.lateral-g.net/members/skelton/
      What I gather from your response is that it's not necessarily about the suspension or travel of the suspenion but rather how low my tires will allow me to go? I have seen cars tubbed out in the rear and know it creates extra clearance, so you're saying I'd need to take that route to get the look you have with the Olds?
      In other words when you say the rear of your car was redone with tunnel fabrication you mean you cut out the inner fender wells and rebuilt new wheel wells to accomodate 20" tires and giving you the clearance to lay it lower to the ground? Did you shorten your axle length so you can also run a wider tire?
      Again thanks for your input
      Robbie
      1964 Chevelle
      396/TH350
      May 2001
      Mesa, Az.
      Robbie,
      It is all about suspension travel. When I say we did tunnel modifications I mean just that. We cut the back half of the tunnel and raised it 4". This is to accomodate the pinion and the drive shaft at its new height. We also C notched the frame to give the axle more room to go up into. Along with that I had to raise the front of the trunk floor to give the upper trailing arms somewhere to go. Not to mention we built custom longer upper trailing arms. Search 65 Oldsmobile in the project section and you can see a lot more photos of the car. As a side note there is no work done to the rear tubs. We are running 275 35 20s on a 20x8.5.
      Phillip
      Oct 2005
      Jasper,IN
      Here is a pic of our 66 Chevelle. Fully deflated it will sit on the factory bumpstops. Can't get much lower than this without doing all the mods that Phillip was talking about.
      Scottsdale, AZ
      Darren, I really appreciate the details and giving me an idea of pretty much where I will be at without doing the tunnel or c-notch fabrication.
      Robbie
      1964 Chevelle
      396/TH350
      Sep 2008
      Kathleen, GA
      64 Chevelle rear Cool Ride with Strong Arms
      Scottsdale, AZ
      I mentioned I am looking to run 18 x 8 on the front and 20 x 10 on the rear. I need to find out what back spacing I need to run... anyone have details as to where I can find this or the proper way to measure?
      Robbie
      1964 Chevelle
      396/TH350
