      Oct 2010
      Carlsbad, CA
      Wilwood Disc Brakes
      I have attached a picture with this link showing my front Wilwood disc brake setup. I have rear drum brakes and want to upgrade to discs.
      Here is the question: can I move this 11" rotor to the rear and get a larger rotor for the front? I have 18x8 rims front and rear and there is plenty of room to accept a larger rotor.
      Paul
      http://gallery.me.com/quailpark#1004...or=black&sel=0
      Current Stable
      '68 Camaro SS
      '13 Audi S4
      '99 Mazda Miata converted to Spec Miata
      '04 F350 Diesel
      Out to Pasture
      '06 BMW M3
      '05 Factory Five Cobra
      '07 Ultima GTR
      '06 Corvette Z06
      san diego
      You might be able to if the bolt pattern on the rotor is the same as the hat you will use in the back. However, to use a wilwood internal drum parking brake you need at least a 12.19" rotor.
      Frank at prodigy can help you out. Also the wilwood site has all the different rotors and bolt patterns so you can build your own kit. They have dimension and drawings for all the parts, spending time on there will help with all your options.
    Tags for this Thread
