    Page 3 of 3 FirstFirst 1 2 3
    Results 41 to 50 of 50
    1. #41
      Oct 2009
      New Derry, PA
      Well, results are inconclusive... We had one pull that showed 505hp / 670lb ft (no that's NOT a typo) at 5000 rpm. Then we couldn't back it up. Blew a charge pipe off, then this, then that...then we gave up. 3 pulls around 450hp / 510lb ft and we called it quits.
      Under load, the turbo went into boost as soon as we cracked the throttle...
      Boost (and hp) were falling off past 5000 rpm. We wre simply running out of air, so I'm wondering if these 2 turbos are really the same after all. Time to do some measuring...as there are no markings on either turbo. Won't help much on a twin setup if the turbos are different.
      Going to concentrate on getting the twin setup together and getting the 327 built. Guess we're done for awhile.
    2. #42
      Oct 2009
      New Derry, PA
      OK, so it wasn't much of a mystery...
      The turbo we used in the first tests (right) was a 60mm, this one was about a 54. No, I never sat them side by side, never had time or a reason to...
      There are no more of the larger size around, so I'm going to swap the big one to the diesel guys for a matching small one. Probably take some time to get it all together. I'll keep you posted if there are any interesting developments...
    3. #43
      Feb 2002
      Springfield, MO
      Is this chassis dyno or engine dyno power?
      Jimmy
      69 Camaro Twin Turbo'd
      58 Nomad 348 Baby Rat
    4. #44
      Southern Indiana
      Hey Jimmy, he is using the schools dyno I believe. No car involved.
      Lee Abel
      AFTERMARKET PERFORMANCE
    5. #45
      Feb 2002
      Springfield, MO
      That's what I figured, good power!!
      Jimmy
    6. #46
      Jan 2010
      Calgary, Alberta, Canada
      I think you need to look at it as an whole system, not just the components. You're putting a dramatic amount more air mass at higher velocity and density through the motor. All those things add up to a non linear increase in friction, resulting in decreased gains at higher RPMs. If you boost limit the turbos with a waste gate then your effective boost goes down as RPM goes up. PSI at the waste gate - pressure drop through the motor = cylinder boost. Say at 3000 rpm you have 1 psi pressure drop through the motor (from turbo to spark plug) and then at 6000 rpm you have 2.5 psi pressure drop though the motor. You're effectively droping the in cyclinder boost by 1.5 psi.
      This is why the new motors do so well under boost. The heads flow so well but they're under cammed in an NA setup. Add pressure and because they provide such an efficient flowpath, they make huge power numbers and can live with higher boost and CR.
    7. #47
      Oct 2009
      New Derry, PA
      Article on the original turbo setup is out in the Jan 2011 issue of Auto Enthusiast. Titled "Learning Curve". I don't know who Kevin Harper is, but he did a good job of rearranging a few words in the story I wrote...
    8. #48
      Long Beach, Ca
      Any news Ray?
      Jon Rasmussen
      Ex Team OLJ.
      '72 Nova
    9. #49
      Oct 2009
      New Derry, PA
      Quote Originally Posted by Nessumsar View Post
      Any news Ray?
      Naah...politlcal infighting stalled it. Another dept. didn't like the fact that we got some ink with "their" borrowed turbos, I guess. I've kept rolling on the little stuff that I can control.
      I'm back to teaching Chassis Fabrication come January, so I may get the Magnum down there to finish up the drivetrain and get the turbo headers built. We never could find any stock manifolds that would mount the turbos where they needed to be... The 327 is waiting on the piston/rod assemblies to get back from the machine shop. Maybe next class the High Perf guys will get it put together. The Stealth Ram and Edelbrock E-Tec heads have been match ported, and the adaptor plates for the dual 4bbl TBs are done.
      I'll try to get a couple pics up if I get it all bolted together, but this one's gonna go quiet for awhile...
    10. #50
      Oct 2009
      New Derry, PA
      Just found this: http://editions.amospublishing.com/K...spx?d=20110101
      It's the online version of the magazine. If you click on the cover it opens. Article starts on page 30.
