      Jan 2000
      Thousand Oaks California
      Engine vacuum. How much vacuum does your engine pull rolling down the freeway?
      I have always suspected the vacuum gauge in my dash was wrong. I'm running twin turbos and a can that should pull a lot of vacuum but I doubt in the high 20's on flat level ground at 65mph.
      When going down hill with the throttle closed it runs very very close to 30"
      Does that sound right?
      Larry Callahan
      Aug 2001
      Wilton, CA. (Sacramento)
      Quote Originally Posted by Larry Callahan View Post
      I never saw more than 22 or so on hard decel with my twin turbo.................. and that was with the stock LS2 cam that made 19" at idle............. Think I had close to 20" with the larger turbo cam on decel, made about 13-14" at idle.
      Jody
      Mine idles about 13-14 and at 75 down the freeway about 15. I am at about 5000 feet elevation and I think that makes a slight difference on how much vacuum you can pull.
      Turbos, 1700.00
      Hot Side, 1500.00
      Cold Side, 1,000.00
      Fuel System, 1,000.00
      The look on the face of whomever the passenger is when the tires break loose at o say 70 mph or so........priceless
