      Feb 2002
      Bay Area CA
      Bouncing Fuel Gauge
      So...I can't take it anymore. I've had one too many people ask me why my fuel gauge is bouncing around like a 5 year old who's had too much soda and pop rocks before bed. Due to my unbaffled tank, the only time I get an "accurate" reading of fuel level is when its empty, full, or I'm at a stop. I'm using a Stewart Warner #114224. Any suggestions?
      -Ian
      1973 Formula 400
      LS1/T56/3.73's
      Daily Driven.
      Marshall , MO
      First guess
      bad ground on the sender at the tank?
      Brad Shepard
      69 Malibu
      Marshall, MO
      Feb 2002
      Bay Area CA
      It's not a ground issue, the gauge just responds instantly to the perceived level of fuel in the tank as it sloshes around. You can, and I have, taken the sender out of the tank and moved the float by hand. The gauge reads just fine and will move as fast or as slow as the float. I know the old stock original gauges used to be buffered with a thick fluid, and now I'm reading about Fords using an "anti-slosh module" in their gauge setups.
      -Ian
      1973 Formula 400
      LS1/T56/3.73's
      Daily Driven.
      Feb 2002
      Bay Area CA
      I can't be the only guy experiencing this problem. I know some of the high end cars on this site have SW gauges, just deal with it?
      -Ian
      1973 Formula 400
      LS1/T56/3.73's
      Daily Driven.
      May 2006
      My Autometer does the same thing. I have been told that resistors could be added to the signal line to slow the reaction to the sloshing fuel.
      Does anyone know if this would work?
      Feb 2002
      Bay Area CA
      A resistor won't work, it will just change the reading of the gauge up or down. A capacitor from the signal line to ground may work, though I don't know how large you should go or if there are any risks of sparks within the tank at the sending unit...
      Does Bad Penny have a cracked out fuel gauge?
      -Ian
      1973 Formula 400
      LS1/T56/3.73's
      Daily Driven.
      69LAnd
      maybe he ment a capacitor ...that should dampen the voltage spike ? like a tig pedal ?
      Rick M.
      hMMMMMMsss....
      1969 Camaro real RS SS DSE LS3 6M TWiiN TURBO in the make!(taking forever!!)..any donations apreciated hehe
