    Results 1 to 20 of 25
      Oct 2010
      Rockaway. NJ
      67 GTO Rear Suspension Q's
      Hello, new here....
      I am looking to take my GTO suspension to the next level..... not go crazy, just notch it up a bit.
      What I have...
      Hotchkis Springs Front and Rear
      Poly bushing in front control arms
      1.25" Front bar out of a TransAm
      Bilstein Shocks Front and Rear
      Aftermarket Upper and Lower Rear control arms ( too many years ago.... forgot brand)
      7/8 GM rear sway bar
      First thing I am considering is the ADJUSTABLE TRAILING ARM MOUNT BRACES..... such as these from PMT
      http://www.pmtfabrication.com/Produc...nt-braces.aspx
      As much as I love Hotchkis stuff.... these are 1/2 the price of Hotchkis.... is there a difference?
      Next thing is a rear sway bar upgrade....
      Couple of choices from what I see....
      1. 1" Solid bar that connects like OEM to the LCA's
      2. Hotchkis Extreme Bar - Does mount to rear axle assembly, but still only mounts to forward hole of LCA's
      3. A bar that mounts to the rear axle but also mounts to the frame such as the Spohn/SC&C Touring bar
      I am only running 15" wheels with 60 series tires....
      At what point is overkill as far as the rear bar is concerned?
      Will the extreme bars hurt ride quality?
      Has anyone used the Hotchkis Extreme bar?
      Would love some opinions....
      Thanks in advance
      Troy
      Oh.... gotta just show her off a little
      Troy
      67GTO
      Dec 2007
      Salem, OR
      Hi Troy,
      Welcome to the site. Nice GTO.
      I only have springs and Varishocks in the back so far and I have been reading up on suspension pieces. From what I've been able to gather the rear sway bars that mount to the frame are a good way to go. I haven't read about the Hotchkis ones that only use the forward hole, but I've heard the stock ones bind the suspension the way they mount to the lower arms.
      I don't think for the braces that there would be much difference between the brands. As far as the arms, everyone seems to really like the Currie ones with the Johnny Joints. I believe DSE has some new arms with a swivel type end too. My current setup to prevent rear suspesnion bind is 44 year old stock bushings.
      I don't have a rear bar right now and mine seems to do okay without it.
      Mike R
      '66 Olds Cutlass Convertible
      '15 Challenger SRT 392 (DD)
      '72 Pontiac LeMans (wife's toy)
      May 2008
      Chicago
      I have a complete Hotchkis setup front and rear on my 67 Chevelle and I love it. Granted I don't road race it but it handles like it is on rails.
      Oct 2010
      Rockaway. NJ
      Quote Originally Posted by kochevy67 View Post
      Which rear bar? Normal Sport Bar or the Extreme?
      Troy
      67GTO
      Feb 2008
      Texas
      I have the hellwig adj rear bar. I had it on its tightest setting for drag racing. Then I got tired of the way the car rode with it like that so I put it on its loosest setting, It took me about 30 mins to change it, but would have taken a bit less if my exhaust wasn't in the way Now the rear suspension doesn't feel so stiff and it will oversteer a little instead of understeering like when it was on the tightest setting.
      Its not a bolt on deal though you would probably have to take the rear springs out to drill the holes for the mounts for the sway bar links.
      http://www.youtube.com/user/cutlassrkt?feature=mhee
      69 cutlass - 5.3l L33, Jakes stage 3 4L80e, 275/40/17 proxes tq
      Central Illinois
      Why in the world would trailing arm braces need to be adjustable? You just bolt them in.
      '68 442 convertible
      5 SPEED - EFI
      '66 442 Hardtop
      in process
      Feb 2008
      Texas
      Quote Originally Posted by CHILI442 View Post
      yeah I don't get it either
      Aug 2008
      Pgh, PA
      Maybe just so that a single part fits multiple applications? Dunno.
      '66 GTO Vert Project "Red Ink", 462ci of stroked pontiac power, TKO600, SC&C Stg II+, Tubular lowers, Currectrac Rear suspension, Moser 12bolt w/Truetrack, Wilwood Master and discs all around, too much fun for words...
      Oct 2010
      Rockaway. NJ
      I would think there is some variation between car to car for the distance between the upper and lower control arm mounts...
      Troy
      67GTO
      Feb 2006
      Quote Originally Posted by 67gtonut View Post
      Exactly.
      Alex Godsey
      Somerset, KY
      Pro Touring 67 GTO
      461 Pontiac Power
      Central Illinois
      Whatever. Never had a problem with the Hotchkis ones I bought for me '68 442. Maybe I just got lucky. Everyone and there mom has been building these braces for years, and I've never heard of anyone having a problem making them fit. Nevertheless, this guy built a better mouse trap
      '68 442 convertible
      5 SPEED - EFI
      '66 442 Hardtop
      in process
      Auburn, WA
      Larger anti roll bars will hurt the ride quality compared to smaller ones in a one-wheel bump (which most are). If I were you, I'd purchase items all from one company to make sure you have a balanced combination of parts. Many people mix and match and end up with a car that under or oversteers too much, or rides harsher than it should.
      Matt Jones
      Mechanical Engineer
      Art Morrison Enterprises
      Oct 2010
      Rockaway. NJ
      Quote Originally Posted by silver69camaro View Post
      Thats one of the reasons I was leaning toward the Hotchkis bar..... but I was told on another forum.... because it still hooks to the LCA's it doesnt do much.... Hard to believe.... so it leaves me questions....
      Troy
      67GTO
      Auburn, WA
      I don't see why it wouldn't work. If the bar is sized properly (which it looks like it is) to work with the motion ratio, I don't see any problem with that. I'd say the MR is pretty low, but it looks like they took that into account when they selected whatever bar size that is. It looks pretty darn large (I'm guessing 1-1/8" x 0.156").
      Matt Jones
      Mechanical Engineer
      Feb 2008
      Texas
      Though with the adjustable rear sway bars you can tune out ride harshness. And it can help fix understeer and oversteer.
