    Results 1 to 20 of 20
      Feb 2002
      Springfield, MO
      2006 Powerstroke-Quick advise please!
      I have an 06 Ford Powerstroke and it is in now for warranty head gaskets and I was going to stud it and had a friend that had some black onyx or (something like that) head gaskets that was sitting on his shelf and I was wondering if they were worth the money or was the stockers good enough? Also should I do the EGR delete kit and if so, where is the best place to get one?
      I will prolly chip it after all this gets done and out of warranty, so keep that in mind.
      Thanks!
      Jimmy
      69 Camaro Twin Turbo'd
      58 Nomad 348 Baby Rat
      Oct 2006
      Phoenix, AZ
      Definitely do the head studs while the labor is on Ford's nickel. I don't know anything about brand or type of head gaskets. I buy all of my Powerstroke parts from Dennis at ITP Diesel. Great guy, he only sells what he would use on his truck. I know a lot of people that have used his EGR delete kit, among other things.
      Jeff K.
      69 Camaro SS, 406 SBC, TKO600, 9" w/3.73 tru-trac, Speedtech Arms, AFX Spindles, Lee 670 Box, Baer GT front, C5Z rear. Hyperco Leafs w/ Fays2 Watts Link + Varishocks.
      Feb 2002
      Springfield, MO
      Thanks Ill check him out, anyone else?
      Jimmy
      Southern Indiana
      EGR cooler delete or up grade, head studs, never heard of the head gaskets but if its listed as a better part in regualr use go for it if they will. I also know a lot of people who do away with variable geometry turbos also.
      If you see the cab off dont worry its normal!
      Lee Abel
      AFTERMARKET PERFORMANCE
      Feb 2002
      Springfield, MO
      Thanks Lee. I had heard that they yank the cab. It's hard to believe that is easier than working in the engine compartment, but I guess it is!
      I'll leave the turbo now since it would be something expensive to do and they prolly wouldn't do it anyway.
      I'm still trying to do research on the gaskets tho.
      Jimmy
      Sep 2009
      washington
      Feb 2006
      Baton Rouge, LA.
      I would 100% recommend the ARP studs. The new redesigned factory head gaskets work just fine with the ARP studs. We have not seen any failures with this setup.
      You should check out bulletproof diesel for there egr coolers. They are a better design and come with a lifetime warranty. (which is saying alot on a 6.0)
      Also I would recommend changing the engine oil cooler. They will be right there at it so it would only cost you the price of the oil cooler. I know they are expensive but it WILL fail in the furture and then it will really be expensive.
      Good luck!
      Terry
      Feb 2002
      Springfield, MO
      Thanks guys, I ordered a EGR delete from Sinister today (which ITP is owned by now I guess). Hmm, the oil cooler is something I hadn't thought of. Is the factory one a good replacement or is there another brand that is better?
      Jimmy
      Burleson Tx
      Factory cooler is fine. Egr delete is a good thing. Be sure to replace STC fittings on the HP oil pump when your this far in.
      Kenny
      Oct 2006
      Phoenix, AZ
      Quote Originally Posted by shmoov69 View Post
      Wow, I didn't know that about ITP. I haven't had the dough to buy any fun diesel parts in a long while so I guess I'm out of touch. I hope Dennis didn't have to go back to a day job!
      Edit: Sounds like they've just rebranded themselves and are still expanding, so I'd say it looks like they're still doing well.
      Jeff K.
      Feb 2002
      Springfield, MO
      Rattin, smattin, stinking piece of.....!!!!
      Well, there was a weird whistle noise under the hood off and on for a couple months now and I finally took it in and they said they found it....it was the overflow/radiatior cap. I said that doesn't sound good, he said not for you!!!
      Freaking head gaskets again!!! He said that he has never seen one come back that was studded. WhooHoo, I'm another "first"!! :-( I don't even drive the thing hard, heck I might full throttle it maybe once a month!! Don't tow that much, some but not alot.
      Well $3,000 later and I got new head gaskets, except Ford ones this time and not the Black Onyx (or whatever they were called). I would NOT recommend them.
      What else is going to fail on this thing? Is it going to start eating cash at 140,000 miles now?
      Jimmy
      Dec 2010
      Fredericksburg, VA.
      Did you subscribe to Diesel Power Magazine? If not, do it!
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      https://www.sema.org/rpm-faq.
      Nov 2011
      yeah those black onyx are junk, OEM are stronger. I have lots of buddies with diesels, and I have an 08 6.4L power stroke, and we all use OEM
      Justin Hocking
      67 Mustang Coupe to Fastback swap
      TCI front and rear
      Detroit Mini Tub
      Future coyote
      Feb 2002
      Springfield, MO
      Well, that's what I got now, stockers.
      So, is it gonna start eating maintenance now?
      Jimmy
      Nov 2011
      shouldn't. also be sure to only use the recommended oil filters from ford. heard lots of ppl had issues with using aftermarket ones.
      Justin Hocking
      TCI front and rear
      Detroit Mini Tub
      Future coyote
      Feb 2002
      Springfield, MO
      Hmm, I've always used wix and rotella around every 9-10k. Is that too long? I thought it was ok for a diesel. ??
      Jimmy
      Nov 2011
      i do 6,000 miles
      Justin Hocking
      TCI front and rear
      Detroit Mini Tub
      Future coyote
      Nov 2000
      O-town
      its a ford, yes, now it will become a maintenance hog,
      I don't understand, It's like a switch was turned on,
      Nov 2011
      if you bulletproof them, they won't become "maintenance hogs"....i have a lot of buddies that have fixed theirs, and haven't had a single problem since. and they ABUSE them. they play in em, pull them, hot rod them. if built right, the 6.0 is way more than the 7.3 ever was
      Justin Hocking
      TCI front and rear
      Detroit Mini Tub
      Future coyote
      Feb 2002
      Springfield, MO
      Wow, didn't know that the 6.hoe would ever equal a 7.3! (with the exception of the cam sensor!)
      What are the new 6.7's doing wrong? Problems with them yet?
      Jimmy
