    Results 1 to 20 of 37
      Nov 2009
      Bethlehem, PA
      Help--headers glowing red in the daylight
      I changed the heads to alum and higher flo. I changer the rockers arms from 1.5 to 1.6.
      I changed the intake to an RPM AIR GAP.
      The hearders got so hot they caught a spark plug wire on fire.
      I have procomp alum heads and have champion spark plugs no. 89.
      It will not idle and only runs if I goose the throttle. If I wholed it in place it dies out.
      Do I need a higher jet size. I have a Holley 670 street avenger carb stock jetting.
      Please help!!!!!!
      Apr 2004
      OKC, OK
      check your timing
      Mike Redpath
      Musclerodz & Customz
      405-288-0189
      pro-touring parts specialists
      Musclerodz.com
      facebook page
      instagram
      Musclerodz
      Dec 2009
      Are all of them getting red or just one or two? One time I saw a valve get stuck and do that. As soon as it got 'unstuck' the headers did not get as hot...
      (Mike is prob right, though - unburned fuel can act like a cutting torch)
      Ron in SoCal
      69 Camaro in progress
      Used to be known as flash911
      Jun 2010
      Quote Originally Posted by MuscleRodz View Post
      check your timing
      same thought
      Papillion, NE
      Quote Originally Posted by SSMuscle View Post
      same thought
      X3
      Advance your timing
      70 Mustang - 489 cid FE, KC ported Edelbrock heads, Modified Victor Intake, Mass-flo EFI, Erson valvetrain, Supercomps, TKO-600, 4.10 9 inch.
      71 F-100 4x4 SB 4x4, 461 cid FE stroker, Edelbrock Pro-flo 4 EFI
      13 Ram Laramie 2500 4x4 6.7 diesel - trailer puller
      Aug 2006
      Easton, PA
      sounds to me like its running too lean. but of course, check the timing.
      what engine? how did you set initial timing?
      Keith C.
      Little Rock, Arkansas
      Sounds lean to me.
      May 2002
      Northern California
      what kinda car are we talking about? have cats?
      you got some major vac leaks or a bum carb.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Nov 2009
      Bethlehem, PA
      Red headers
      It is a 350 sbc bored .060 over
      Timing is fine. It runs smooth when running. I had a vacuum leak once and the engine bucked all over so I do not have a leak I believe.
      The cam is .485 lift at 1.5 ratio so new lift would be .517.
      Car is a 1973 Camaro. No cats. 2.5 inch exhaust. Carb ran fine before the upgrades. Could it be that lean for the upgrades?
      Do you think I should try like 4 jet sizes?
      Papillion, NE
      Quote Originally Posted by Type73LT View Post
      You say timing is fine, but what is the timing set at? and are you sure the balancer didn't move on you and the advance is working properly?
      I would be AMAZED if it was jetting, especially if they are hot at idle
      I'd triple check the firing order, check with a timing light, and verify TDC
      Before you bathe it in fuel with a big jet change (which it shouldn't need) let us know exactly when the headers glow
      Jan 2002
      Crockett, Texas
      Sounds lean to me too, but of course at idle the jetting has nothing to do with it.
      As mentioned, advance the timing and adjust idle mixture screws with a vacuum gauge to get the highest reading.
      Don 67 Camaro RS/SS Texas
      Most likely your higher flowing heads also have larger runner volumes. You switched to an AirGap from probably a Performer dual plane? Both changes (and to a small degree the rocker arm change) will probably have less of a vacuum signal at idle, part throttle, and low rpm full throttle operation.
      Adjust your carb as stated earlier, adjust the curve so that you can increase your initial without changing your total, and confirm that your rocker arms are adjusted properly.
      Nov 2009
      Bethlehem, PA
      It will only idle for a few seconds and I have to goose the throttle to keep it going. If I hold the pedal steady at say 1500 rpm it again starts to die out and I have to goose the throttle again.
      Timing is at 8 degrees with out vacuum hooked to the distributer. I have backed out the idle mixture screws another half turn and it may have help some but still dies idling.
      I do not know if these spark plugs are close to what I need....Champion number 89. That is what the counter guy said to try. I asked The company I bought the heads from and procomp and neither would give me a recommended plug heat range to start with. I know I will have to change to shorty plugs because the boots are just to close to the headers. To get the right ones I need to know how close I am now with these 89 plugs.
      Should I try a different carb? or just increase the jets first. I have a 780 vac sec card and a 650 dp. Both were set up for the old set up of the engine so if it a jet problem then they too would be wrong.
      Papillion, NE
      Sounds like a possibility of a few things.
      1st, how did you adjust your valves? Sounds like maybe you have a tight one or two
      2nd - Advance your timing to 14 for now. You really will need to recurve later, but if its a timing issue or a slipped balancer, it'll start idling well and cool right down, then we can figure out whats happening.
      If the valves are adjusted correctly, the idle problem then sounds like a bad vacuum leak, I'd pull the carb and look at the imprint on the base gasket, you may find its sucking air
      DO NOT do the jets, I know you are itching to do it, but it wont do a thing. It is 100% positively not a jetting problem or a plug problem.
      Papillion, NE
      Also, A Champion 89 is an RC12YC variant, one of the most common plugs for SBC, SBF, BBC, BBF, FE Ford aluminum heads, its a good start for what you are doing
      Pull the plugs and see if they are carbon fouled. Could be why your not able to get it to idle right now. Its going to at least need to idle on it's own so you can make adjustments.
      Leave the jets alone for now. Won't do a thing to fix your idle issue. Also, does it look like fuel is coming from the boosters at idle? Blown power valve or throttle blades opening past the transition slot would add too much fuel at idle and make the idle screws useless. You can figure out if you're past the transition slot by hooking up a vacuum gage to the ported spot on the distributor and see if you get a reading.
      What's your engine specs? (Compression ratio, displacement, cylinderheads, and camshaft)
      Did you spray carb cleaner around the intake base and carburetor base to check for air leaks?
      Nov 2009
      Bethlehem, PA
      OK I found a vacuum leak...well not a leak but dummy me. I took off the power assist hose putting on the spark plug wires and forgot to put the hose back onto the intake. So I also took the idle bleed screws out 2 full turns. It idles smooth now...no goosing the pedal, the choke works fine. Timing is at 10 degrees without the vacuum hose hooked up. It sounds much stronger than it did before even out the exhaust.
      BUT THE HEADERS STILL GLOW. Even at idle after 2 minutes they start orange-ing up. So i shut it off not wanting to do more damage then I may have already to the headers.
      Again what I changed so far....
      Went from 186 fuelie heads with 1.94 values to Procomp 190 heads with 2.02 values same 65cc.
      From Weiland stealth intake to RPM Air Gap.
      Kept the Holley street avernger 670 carb so far.
      From stock 1.5 rockers to 1.6 on a was ,485 lift cam which should be a .517 lift now. and I kept the anti pump up lifters also.
      I also switched headers from 30 year old Eagle headers to Summit ceramic coated. That is why I will be switching to shortie/header spark plugs. Just not much room at the bends.
      When I adjusted the lifters I did it by the book. I by hand turned the nut until the new push rods stopped turning in my other fingers. turning the motor to keep them on the base circle. Then I went back and took them all 1/3 turn more. Which will have them a little on the loose side for more rpm.
      Still need ideas why all the header tube start to glow. If I raise the rpm the glow faster. At idle they start at about 2 minutes.
      May 2010
      Orange, CA
      You need a bunch more timing. You are not only putting unburned fuel through the exhaust that is igniting in the headers, you are also transferring much more heat to the cylinder walls because it is burning long after piston is heading back down.
      Start at 14-16 degrees and see if that doesn't help.
      Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming 'WOW What a Ride!'
      Long Beach, Ca
      Your initial timing is still too low. Try what 427stang said and get it to 14*-16*. I have my 383 set at 18 initial, 36 mechanical, plus vacuum.
      Maybe your coil is dying?
      Although I don't believe this is all of your problem...
      edit: Don posted as I was typing.
      Jon Rasmussen
      Ex Team OLJ.
      '72 Nova
      Nov 2009
      Bethlehem, PA
      I will try more timing. I have a new distributor and 6al ready to put in but I want to make sure everything I have changed is working first. I do not want to make so many changes and something is not right with a list so long.
      I did not pull the motor and only turned it over to adjust the rockers with no plugs in. I could have turned it free hand almost. I never touched the Rattler balancer other than the center bolt.
      I have been using a Ignitor 2 pick up and a Mallory Voltmaster coil. I once had a GEO Metro. 3 clynder and a 5 speed. It started bucking on the way home. I did some testing and guessed the coil was going. I had a Accel yellow super stock coil from the camaro from before the Voltmaster and put it on the Metro. Never a problem again. I put over 300,000 miles on it and it still did not burn oil and would spin the tires thru 2 gear. I broke down and want AC so I traded it in.
