Results 1 to 10 of 10
Thread: 4l80e
09-20-2010 #1
4l80e
So I going to the swap meet this weekend and will be on the hunt for a 4l80e for my 69 Camaro. I am looking to swap out my Th400.
Is there any particular year that I should look for? Also, does it matter if it’s out a truck with 2wd vs 4wd ?
Any part #’s that I’d need to look for on the case?
Joe C
1969 Camaro
09-21-2010 #2I know you definitely want a 2wd version. I believe the recommended ones are pre 1996 (or 97?)....like from the vans. Might want to ask CRITTER on here...Chris Ritter. He has experience. Or Jakeshoe....he actually builds/sells them and installs them. I believe the real difference is the earlier versions are a little smaller in some aspects and fit many conversions easier.
1973 Trans Am 455 SR block, ported 6x-8 heads, solid cam, Victor intake, 830 CSU carb, aluminum rods, 77mm Garrett turbo and methanol injection. 1064hp at the flywheel@5500 rpm
09-22-2010 #3
