Results 1 to 20 of 26
10.3-1 compression with 10psi boost?????
My procharger is comming.. Ill have it on MONDAY..
I was going to pull the intake and heads and headers and install .080 head gaskets to drop the compression down to 9.3-1.. (aluminum pro 1 heads)
Doing this is a real PAIN..
What would the possiblities of running the high compression with the 10lbs of boost from the procharger.. and if so... what fuel would i have to run??
Or should i just suck it up and pull the heads..??Project JUST-N-SANE
84' Camaro Z-28, 355CID,9.0-1 compression, ATI procharger 9psi (over 650HP),T56 6 speed, 3.73 Motive gears! 11.70 at 122mph in the 1/4 while babying the throttle to keep the tires hooked ,with pump gas! (NOW INTERCOOLED)
