    Thread: sandblasters?
      Feb 2008
      Melbourne, Fl
      sandblasters?
      Before we start I know all about harbor freight. Just my budget is super small. So that being said, is the a performance difference between these two? One work better on smaller compressors? They look to do the same thing just seal different and filling on one looks easier. Please help. Thanks
      http://www.harborfreight.com/90-lb-p...lid-93889.html
      http://www.harborfreight.com/110-lb-...ter-95014.html
      Aug 2009
      I use the second one, but it does take a good compressor to keep up. The blaster works great, but just make sure to filter your sand before putting it in the tank or youll spend lots of time taking it apart. The little hood that it comes with sucks, so just throw it in the trash and buy a decent hood from Ebay or somewhere. I cant comment on the first one, but the one I have works excellent with DRY FILTERED play sand.
      Central, Ky
      Do you use it quite a bit? or occasionally? Good info to have, I need a cheap one.
      2003 Crewcab Dually Dirtymax
      1980 Malibu...6.0 LSx turbo on the stand.
      2000 SS th400 little juice
      2002 C5 glide swap, motor shopping
      1970 Nova... still waiting.
      Aug 2009
      Mine is only used occasionally. I really dont think any of the cheap blasters are made to be used everyday. The nozzles do wear out after a few hours but are cheap to replace.
      Central, Ky
      Im not looking to be professional, just save some money over out blasting con-artist.... ;)
      Melbourne, FL
      If you do buy from HF look through most of the current magazines, Car Craft, Hot Rod, PHR, etc ... most have ads in them and a 20% coupon.
      67 Firebird Convert 455 +.060 Johnny Winters TH400 74cc KRE d-port flowed @ 310 cfm heads piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.55 Detroit Locker M/T Sportsman Radials 31x18x15 on Convo Pro 15x15s
      Honest dad that 455 on the side of the block is a serial number
      Feb 2008
      Melbourne, Fl
      Quote Originally Posted by 67 455 Bird ragtop View Post
      thank you I have a ton of them.
