    Thread: seat studs?
      San Bernardino, CA
      seat studs?
      i seem to remove my front seats quite a bit to fiddle with stuff under my dash. would it be a no no to use studs to mount the seats in my 69 camaro? its such a pain in the butt to line the bolt holes up and install the bolts. i think it would be much easier to drop the seats in over the studs and be done with it.
      stock 69 camaro seats by the way.
      Aug 2006
      San Francisco, CA
      Quote Originally Posted by DCx View Post
      yep! I use studs. Just put loctite on the threads otherwise it just spins when you try to thread down the nut.
      The better way to do it is to put bolts from underneath the seat frame...but that's more involved.
      Steven
      1968 Camaro: Project "TRACKDAY"
      Latest Track Weekend Video
      Build in Progress
      Den Helder, the Netherlands
      Country Flag: Netherlands
      Crown Point, Indiana
      I thought the same thing I used studs, but when I took the seats out to get under the dash the suckers poked me in the back. I went back to nuts and plates welded to the underside of the floor and then when I put he seats back in I just run a longer bolt through the nut and then put a nut on top after the seat was in. I have removable studs so to speak.
      Apr 2008
      Newark, OH, / Concord, NC
      Studs are usually grade 5 or better so they will definately strong enough.
      IF COMMON SENSE WAS COMMON EVERYBODY WOULD HAVE IT
      Nov 2010
      Great info, will be using studs for my seat!!
      68 Camaro RS twin turbo
      Slow Lifted Jeep No TURBO :(
      Randal F
      Cornettsville, ky
      my truck has studs oem so i dont see the problem
