Results 1 to 8 of 8
Thread: Help With Initial Setup
08-27-2010 #1
- Sep 2005
- 134
Soo...it's finally time to run my motor and I need a little help with the initial setup. My engine builder is very good but he isn't incredibly familiar with prochargers and blow through. I built a 422 with 8.5 to 1 compression, mildly ported eldelbrock heads and an F1 procharger. I am loooking to put 16 pounds or so into the motor. The setup is intercooled and is pumped through an 850 holley built for blowthrough. The questions I have are in regards to the Blow Off and Initial Carb setup. I would like to run the motor late next week, my builder and dyno are available so that'd be ideal.
1) I was given one of the big red procharger bovs when I purchased th head unit. How are these performance wise? Will it work with this application? Don't know the part number off hand. Also where is the best placement for it? Close to the hat no?
2) Also I need to get a rough idea of how to baseline this carb/fuel system. Any suggestions or people to talk to would be much appreciated.
Sorry for writing so much tried to keep it to just the necessities. Thanks in advance,
Chris72 challenger
RMS Alterkation
Airbar w/ coils overs
422" R3 motor w/ F1 Procharger
09-03-2010 #2
- Sep 2005
- 134
No one's got anything????
72 challenger
RMS Alterkation
09-03-2010 #3OK...here we go: Procharger has most of your answers on their website, but I'll answer them here. The red surge valve is great. I have the lesser black one. It is best placed before the intercooler, but mine is after it. The carb. jetting should have the primary and secondary jets set up about 4 jet sizes larger. During the dyno sessions you can optimize them. The carb. needs the large needle and seats to aid flow. If the carb. has been modified for blow-thru, this should be already done. Make sure your fuel system is up to the task...I recommend an Aeromotive A-1000 and boost referenced regulator as a minimum. Good luck...sounds like a fun build.
Honey, I don't know how those black marks got on the driveway....
09-03-2010 #4
- Jan 2006
- Miami, FL
- 166
