      Nov 2009
      Jacksonville NC
      Differential Really Hot any opinions??
      Just got the engine back running, and took it on a spin. When I got back I was checking everything and realized the rear Diff housing and tubes were HOT. I checked the brakes/rotors and they were good. The temp reading on the housing was around 150, and 160 towards the fron/top of the housing. The tubes were around 140. The rear end is a 12 bolt moser 373 with posi. I have'nt long put the rear in the car but before I installed it I put a 1350 series yoke on it. I'm thinking I may have got it to tight, unless there is something else you may have a opinion on. I did top it off with oil and the additive. How hot is to hot??
      Dec 2002
      Lost Wages, Nevada
      Normal performance differnetial temperatures will run in excess of 200*F oil temperature. So a surface temperature of around 150*F isnt something I would stress too much about.
      Yea, don't worry about it. That's not excessive.
      May 2002
      Northern California
      Quote Originally Posted by obengston View Post
      i agree with the above but how far was that spin?
      if it was around the block then it might be much...do you have turn down exhaust?
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Jun 2009
      Southwest Florida
      If the diff/gears are new they'll run hot for a while, and anything less than 200 degrees isn't anything to be concerned about like chicane said. Just keep an eye on it and try not to make any long trips during the first couple hundred miles.
      -- Dan
      Aug 2008
      Iowa
      Good question from vince. is the exhaust causing the heat?
      Oct 2006
      Corona, CA
      As stated above, pretty normal. An aluminum cover will help dissipate heat as well....
