    Results 1 to 2 of 2
      Aug 2008
      Pgh, PA
      Strange brake problem
      A very good friend who has helped me a lot on my project has a very nice '53 Ford F100 truck. It's got a '77 or so Monte Carlo front end, a SBC, '77 Monte front calipers, rotors and spindles, and a '77 Granada master cylinder and brake booster. Master cylinder is on firewall. Large reservoir goes to T, then to left/right caliper. Small reservoir goes to prop valve (new) then to rear drum brakes (T over rear end).
      The truck has been driven extensively with no issues. However, not long ago the master cylinder failed, and had to be replaced. The replacement worked, but it ended up leaking (bad quality lid on new part). Now, the new replacement doesn't leak but it's doing some strange things.
      1) The brakes have been bled too many times to count. When the engine is not running, there is very firm pedal pressure, and with the front end of the truck raised, it takes little pedal movement to apply brakes to front wheels.
      2) When the truck is started, the pedal is no longer firm, and goes almost to the floor before engaging the brakes.
      3) Obviously, if truck is running but vacuum line plugged and booster not connected to vacuum, it behaves exactly like when truck is not running.
      4) Booster is not making any noise. No indications that it has failed.
      Based on the troubleshooting I did tonight, I'm thinking that since the brakes seem to engage quickly when the booster is not given vacuum, the problem could not be the calipers, lines, air in the lines, or master cylinder. So, it has to be the booster, right?
      '66 GTO Vert Project "Red Ink", 462ci of stroked pontiac power, TKO600, SC&C Stg II+, Tubular lowers, Currectrac Rear suspension, Moser 12bolt w/Truetrack, Wilwood Master and discs all around, too much fun for words...
      Southern Indiana
      Your probably looking at difference of manual brake master cyl over a power unit. with boost from power unit running its just taking so much movement to get same pressure a smaller bore manual master cylinder would. its an odd ball issue but ran into it several times on Granada parts. Salvage car gets wrong part, then dies hard death, but the non power part works ok with boost but a power master cyl in same project acts like crap pedal. kind of liek guys using 1 1/8 Vette masters having bad manual pedal, they go to 7/8 and tada its fixed. See if you have 1 1/8 bore (just a number , not related to Granada parts, it may have to move 3/4 in to make 500 psi, but a 7.8 ,because of less volume size will build up 500 PSI much quicker resulting in less pedal travel/firmer pedal.
      Booster test, remove all vacuum reserve, by pumping. Then with foot on pedal it should drop when car is started.
      Or you may even have mis boxed master cylinder.
      Lee Abel
      AFTERMARKET PERFORMANCE
