Thread: procharger with accessories
08-28-2010 #1
- Aug 2004
- 81
when running a procharger in a 69 camaro with a sbc can you also easily fit an ac compressor, power steering pump and a alternator under the hood? if yes does anyone have any pictures. thanks
09-26-2010 #2Not easy but have a look at the "Procharged engine bay" on YB you may see something close...... Possibly if you have the eight rib crank pulley with twin v-belt grooves fore and aft. On one v-belt run the GM type II P/S, on the other run the alt and A/C. You will need to sus the brackets or cannibalise existing after-market brackets. Then possibly install an electric water pump.
Draw the front of your block, take measurements and draw the belts. Here's something I knocked up earlier on an abandoned project...
11-17-2010 #3I have a procharger F1 kit (it is for sale btw) w/12 rib blower belt. The supplied pulleys only have 1 v belt groove. You need to use something like the sweets power steering pump with remote reservior (for sale with the blower kit) a/c could be tough with this setup.
