      Jun 2009
      Spring, Texas
      Proportioning valve re-location
      Guys, If this is not in the right sub-forum, I apologize.
      I am running headers on my 69 GTO, and I have succeeded in cooking my brake proportioning valve that sits on the frame about 1.5 inches from the header. I know, I should have moved it previously, but I didn't. What is the best way to re-locate it. I have already replaced all of the hard lines back when I did a frame off 3 years ago. I really don't want to have to run all new lines. What have you guys done, and where have you GM a-body owners re-located your prop valves to. Do you have pictures?
      Thanks in advance
      RW
      can you just fab up a simple heat shield out of some sheetmetal to keep the radiant heat away from it?
      Sep 2007
      Southern California
      If you are talking about an adjustable prop valve, I made a simple bracket and mounted it to the frame under the driver's seat. For tuning it is easy to get to and out of the way.
      Jon U.
      1968 GTO - SC&C Suspension, Forgeline SO3 Wheels
      Build Thread
      1967 911 with a few mods
      Dec 2007
      Salem, OR
      We moved the whole assembly up under the MC on my wifes' car since it has a 455 with headers. We installed all new "conversion" lines from Inline Tube that are made to work with the new prop valve location. I believe you can get just the lines to run from the old location to the new one (since you just replaced them).
      Hope this helps.
      http://s957.photobucket.com/albums/a...t=LeMansMC.jpg
      Mike R
      '66 Olds Cutlass Convertible
      '15 Challenger SRT 392 (DD)
      '72 Pontiac LeMans (wife's toy)
