Results 1 to 20 of 31
Thread: A-Body suspension on a budget
08-24-2010 #1
- May 2008
- portland, OR
- 7
So i wanted to make a thread that could help some people and myself who may be looking at doing the same thing.
Car : 1970 monte carlo.
Current Setup: 427 BB, turbo 350, 3.08 gears detroit true trac, 20" rims 295 30 back, 245 35 front, poly front end bushings, moog lower BJs, new front springs. The car needs shocks badly, rear control arms and springs. front and rear sway bars could use some help. Just had alignment checked but front outer edge of the tires are wearing out due to + caster on turning and body lean from cornering. this may be able to be sorted out with some alignment and sway bar.
Usage: The car is a daily driver I would like to improve the handling a little bit yet keep a nice ride. I doubt i will ever take it to the track but it would be nice to have better handling for some fun.
Questions: I wanted to get some opinions on a low dollar suspension and alignment set up for my car. I am open to take off parts from other vehicles.
Is there any way to use taller ball joints or spindle without doing control arms to save a bit?
Alignment settings : 1.5 degrees of negative camber, 6.5 degrees of positive caster, and set the toe-in 1/8 inch.
I dont know if this alignment is possible with stock control arms but i did some research and this is a dual purpose setting for daily driving and performance.
Shocks: qa1 single adjust or ( non adjustable that would work for less?)
Springs: SPC pro touring
Sway bar Front: take off from?
Sway Bar Rear: Spohn or hellwig multi adjust
Rear control arms: Spohn upper and lower.
this would be about $1800 for the above parts
so ya thats a bit more than I wanted to spend and may not even be necessary for my plans. any suggestions would be helpful.
Some new questions:
I've been doing far to many hours of research but came across some more useful things and some more questions.
Geometry and alignment.
It seems to be that upper control arms with caster built in of the 5 degree mark in combination with a taller spindle or ball joints will provide the largest improvement in the feel of the car.
question: is a lower control arm really of much value for a non competition car? Can I just keep my lower control arm and inspect it to make sure its stable?
Rear control arms and sway bar:
the Spohn or something like them seems to be the best for the arms.
Question: Do you need a rear sway bar? I have read some topics that the rear sway bar actually adversely effects the handling. many of these large rear sway bars are because something else is actually wrong with the car.
Shocks:
I have yet to find some good alternative options of shocks. I know of qa1, vari shock, strange engineering adjustable shocks which seem good at about the same prices.
are there some good non adjustable alternatives that would work I dont want a rock hard ride just better feel and less roll and bounce?
Thanks this place is great.Last edited by deadeyedck; 08-25-2010 at 05:32 PM. Reason: more questions
08-24-2010 #2Not really that important, but you might want to change your thread title to "G-body ....". Monte's are G-Body cars and not A-body. Not better or worse - just different.
08-24-2010 #3
