    Results 1 to 11 of 11
      Feb 2006
      lee quick ratio box
      anyone running a lee quick ratio box in a camaro with an ls motor.. im having problems with the power steering making an awful noise.. doesnt seem to be air in the system.. is there a calibration problem?
      Mar 2002
      Redwood City, CA
      What kind of noise? I doubt engine type would have anything to do with it as it's about the pump, lines, and box itself.
      Allen Ortega
      Lake Oswego, OR
      I would call either Tom Lee or Marcus @ SC&C to help troubleshoot.
      Lee
      1966 Cutlass
      The difference between truth & fiction: fiction has to make sense.
      Build Thread:
      https://www.pro-touring.com/forum/sh...ad.php?t=64470
      New pump also? Whos pump is it?
      Den Helder, the Netherlands
      Country Flag: Netherlands
      Same problem here, problem gets worse once it warms up. I have the regular F-body LS pump. I have a different valve for it but haven't installed it yet. Bought the box and valve through Marcus but we all know how busy he is and thus hard to reach every now and then.
      In all fairness; in my case there could still be some air in the system so I would appreciate suggestions on best steering box air bleeding procedures.
      Oct 2006
      Pittsburgh Pa.
      Call Lee up and ask them for the orifice size for your car... Then drill out the flow valve to the recommended size..
      Only Lee has this info.. You don't need a new pump. The stock GM pump will be fine. I've been running my lee 12:1 for years with the stock pump. I did have to get the proper flow valve orifice size from Lee for my car and drill it out..
      St George Utah
      what resivoir are you using?
      we have seen problems with the Billet Specialitirs remot res, but if you use the Lee resivoir there should be NO issues, i just finished mine and filled it up spun the pump over with a drill turned the wheel a couple times and it is perfect, we have done cars with the BS res and after hours of bleeding and then redesigning the return tube.
      something to check if your using a remote.
      Blake Foster
      www.speedtechperformance.com
      435-628-4300
      St. George Utah.
      it's always sunny here.
      Jan 2007
      CT
      Quote Originally Posted by killer69 View Post
      Have you seen any issue with the KRC setup with remote res with the Lee box?
      ________________
      Nick S.
      Gold/Gray 1967 Camaro
      PA.
      I have to agree with Blake, we have seen some really cool looking reservoirs that are basically "fluid aeration chambers". That`s a possibility. We have all of our Lee boxes tuned to the intended pump`s output pressure and volume so that shouldn`t be an issue. I know this sounds stupid but it could be as simple as a bit of dirt in a fitting allowing a bit of air in. Mark SC&C
      Ramona, Ca. San Diego area
      I went to your website and couldn't see any reservoirs? What are they under?
      67 Camaro convertible (Jinx)
      Oct 2006
      Pittsburgh Pa.
      Quote Originally Posted by Marcus SC&C View Post
      We have all of our Lee boxes tuned to the intended pump`s output pressure and volume so that shouldn`t be an issue. Mark SC&C
      My pumps orifice size was all wrong for the box you sold me.. I called Lee and got it straightened out. He asked me what car it was in and made me wait a few minutes while he looked up the size. The guy from Lee said you need to make sure the pump flows enough for there box. He also said the stock GM power steering pump would be fine and it has been for 4 years now with over 30,000 miles..
