    Page 2 of 2 FirstFirst 1 2
    Results 21 to 21 of 21
    Thread: Twin Turbo Ls3
    1. #21
      Oct 2009
      New Derry, PA
      Quote Originally Posted by RSX302 View Post
      I'm all ears (ok eye's..LOL) and do appriciate your input...
      I know that water is a better heat transfer medium than air(hence smaller turbo intercooler).
      I agree that once you get the heat into the water, you now need to pull it back out using air (1:1 heat transfer with a bigger radiator)
      I haven't done the math but most radiators I've seen don't use the same size as an air/air intercooler.
      Also max 1:1 heat transfer would be based on 100% throttle all the time at max boost. I don't know too many that would plant the throttle with 800+hp 100% of the time? Road racing on the big track at Willow I might see full throttle on the front/back striaghts for less than 10sec? 145mph
      example: 600-1200hp Radiator
      Good info here: http://www.bellintercoolers.com/page...FAQ.html#FAQ_5
      Of particular interest is the last half of FAQ #5... They sell both, so I figure that info is about as un-biased as you can get... My comments were based on a direct comparison of inlet charge temperatures vs heat radiating areas. Obviouly, each type has it's place.
    Tags for this Thread
