Results 1 to 20 of 29
Thread: I am finally done! Pics!!
The title of this thread is probably a little mis leading. You were probably expecting to see the fruits of my labor and how happy I am to finally finish my project. Instead I am done with it. I love my car but the fun is no longer there as the light at the end of the tunnel never gets closer and my funds just don't allow my vision. So, with that being said I am asking your opinions as to what to ask as a selling price for my Camaro. I have not posted too often but when I have, I have always received helpful advise and hope to do so again. Here goes with the description, I am sure I will leave some things out but hopefully I will list enough to get some opinions. So here goes:
Original SS big block car, no x-code but big block cross-member and heater-core were and are in place when I bought the car.
Engine / Exhaust:
383 4-bolt studded block
Scat Crank
6" Scat rods
Wiseco Flat-top forged pistons
Comp cams roller cam 252/252 dur. .640 lift
Comp cams roller lifters
Crane gold roller rockers and stud girdle
Pro Topline aluminum 64cc, 220 runner heads
Weiand Team G intake
Holley 4150HP 950
MSD 6AL
Accel blaster coil on HEI
Accel 300+ wires
Holley Black electric fuel pump and regulator
Proform electric water pump
March alternator and power steering pump pulley kit
K&N Air filter with x-stream top
Doug's 1-3/4" headers (Not Thorley's but Doug's much better IMO)
2-1/2" Flowmaster American Thunder exhaust with H-pipe
Hooker Aero Chamber mufflers (liked the sound much better than the flowmasters)
Drivetrain:
4-speed Borg-Warner Super T-10, Muncie was gone, don't know why
12-bolt rear
Moroso Brute Strength posi differential with 4:10 gears
Suspension / brakes:
2" Drop leafs from Detroit Eaton
2" Drop coils from Hotchkis
Hotchkis front sway bar
Bilstein shocks on all four corners
DSE solid bushings
Guldstrand mod (best all labor no parts improvement ever)
Touring Classics 13" C5 cross-drilled and sloted kit in front (not Hybrid)
Touring Classics 12" cross-drilled and sloted kit in rear
Wheels / tires:
Intro Customs GT Sport 17x10 with 5.5" bs rear
Intro Customs GT Sport 17x8 with 4.75" bs front
Nitto 275/40/17 rear
Nitto 245/45/17 front
Interior:
Covan's classic dash with Autometer Phantom guages
Momo Race steering wheel
Enough with the good, now the bad and ugly. The car needs paint, looks good from a distance because the body is pretty straight but there are some areas that look pretty bad, including a couple of spots that paint has fell off but it still gets plenty of thumbs up and comments when driving. By the way have any of you ever wondered why people feel the need to curse when showing approval of your car, I couldn't count the times I have been told "Bad F***ing ride man". The rear quarters had some idiot (it was me) take a sawzall to them because the tires occassionally rubbed on the rear and still do with any rear passengers. I didn't take into consideration the rear disk brakes when measuring the rear backspacing and they need about 3/16" more backspace. Dave at Intro told me any good machine shop could take 3/16" off the wheel mounting surface without any problems but I haven't done so. There are signs of surface rust in the typical places (drip rails, rocker panels). Someone did a fairly poor dent repair to the driver's door about the size of a baseball that isn't noticed until looked for but again it wasn't done very good. There are a few holes in the floorpan, your feet aren't going to go through them by no means but needs attention, trunk is solid vut bare (no mat). The radiator core support needs replaced due to rust where the original bushings rotted. Front grill needs replaced, has bowed for some reason in two locations. The horn and backup lights don't work. The engine compartment needs detailed. You would never know it but believe it or not I do love this car I just want to get all the details out there.
Now here are some pics:
Chris
Lexington, KY
69SS
