05-12-2005 #1
Project Update: Formula454, upper control arms, lower rad hose, oil cooler
Got some pics for you guys,
Speedtech tubular upper control arms, with stainless billet shafts, with 5 degrees castor built in
Finally got the stainless lower radiator tube in to match the upper, couldn't use the pi-thon lock on both ends, couldn't get it in like that! had to use a hose and T bolt clamps on the water pump. The red power line is temporary
Also got the oil cooler in. Mocal thermstatic sandwich adapter, 10AN braided lines, 19 row Earls stacked cooler. I ran all the lines in the fender along with the electrical wires and hydroboost lines. Took me forever how to figure out where to route the 2 10an lines so they were outta the way of the steering column/shaft and the Z bar, but i finally got it. Couldn't run it along the oil pan because the huge header was in the way
