    Results 1 to 15 of 15
      Mar 2003
      Boringville
      Project UPdate on formula454, Started motor today!!!
      Well after starting the motor 2 months ago and having the cam go flat from somehow forgetting to remove the inner valve springs from only 1 of the heads, i finally got this thing back together and fired it up today. I have never heard such a beast!! This thing sounds so sweet! 11-1 compression, solid roller, Big Block and 3" exhaust make for a sweet sound!
      It started right up and since it is a roller now i just let it idle. Oil pressure is about 25 at idle and 50-60 at higher rpm. I can't drive it yet, until i get the braking system finished.
      Since last time I pulled the whole motor tranny, took apart the engine completely. Then had the motor hot tanked and i reassembled it. I bought a decent dial bore guage and rechecked my clerances and foudn them all to be loose at .0035, so i matched up some different bearings and got my .0025 I was looking for. I also put a Isky solid roller in it with
      288/294 duration advertised
      256/260 .050
      .680 lift
      when i degreed it, it actually came in a little bigger with the duration.
      I also added Isky's Red Zone roller lifters.
      I also put on a Milodon Road Race 8 qt oil pan with like 7 trap doors.
      ALong with the oil pan i put a sandwich adapter with a 180 degree thermostat and ran a oil cooler.
      The exhaust consists of 2" hooker super comp headers with flowmaster 4-2-1 collectors and Flowmasters "D-Port" cross over, and 3" dynomax ultraflows, and Pypes 3" tailpipes.
      Can't wait to drive this thing!! In the next few days I will try and post a video, I can't believe how mean this thing sounds. I had no leaks or anything. Here are some pics
      Mar 2002
      Redwood City, CA
      Looking good Cody. When do you plan on trailering it to the shows?
      Allen Ortega
      Mar 2003
      Boringville
      the day you actually work on your car, oh.....I guess never!
      Mar 2003
      Make it big
      That's looking killer cody!!! Did you get your new hood?
      -David
      Jul 2003
      Anaheim Hills, CA
      And there is no video?? What the hell is this???
      BTW.. somebody stole your fenders..
      Seriously though.. congrats! motor fireage is a milestone for sure...
      1968 Track Rat Camaro:
      Prescott Arizona
      Glad to hear it went well Cody. Looking at the pics makes me wonder if there is any "flex" in your upper radiator tube?
      Brian D
      Snotty Bimmer driver.
      Mar 2003
      Boringville
      yes there is some flex due to the rubber bushing inside the connectors. Also i have one solid motor mount. Didn't we go over this before?
      Mar 2003
      Boringville
      Did get the new hood, VFN 3" cowl. I am thinking down the road i might switch over to EFI and hopefully be able to use a real low pro throttle body and be able to use the stock hood.
      Prescott Arizona
      Quote Originally Posted by yody
      Hmmm, sorry, I don't hang on your every word. Congrats on the fireup!
      Brian D
      Mar 2003
      Boringville
      hey don't you start now too thanks!
      edit, sorry thought you were in this other thread;
      https://www.pro-touring.com/forum/sh...ght=formula454
      my mistake
      Prescott Arizona
      Yeah, I missed the other thread, no heartburn here, the car really does look impressive!
      Brian D
      Jul 2003
      Anaheim Hills, CA
      Quote Originally Posted by Q ship
      Yes very impressive.. has anyone SEEN Yody actually work on it? ;)
      Mar 2003
      Boringville
      Hey! I did EVERYTHING myself including smoothing the firewall and building the entire motor,from measuring everything to assembling the heads. Only thing i didn't do is setup the gears in the rearend. I have spent the last 1 1/2 working on it byself in my moms garage. I live in my own apartment. BTW i am only 24 and pay for everything myself,.....brag.,brag,brag
      Boise, Idaho
      Looking good yody!! Get some sheet metal on the front and get those brakes working. We want some video of your first burnout!
      -Nate
      71 Firebird.....in progress
      Ontario, Canada
      Can't wait to hear it.
      Ken
      My other car is a Vega.
