      Sidney Ohio
      C5 brakes with year one snowflakes?
      I have looked through dozens of posts and cant find a definite answer on this. Do the 17" cast snowflakes clear c5 c6 brake setups? I bought the wheels and am just waiting on the back two to get widened and returned. I would like to start brake shopping but want to make sure they will fit. This seems like the way to go for big brakes on small budget!
      "Cowboys Love fat calves."
      Loganville, GA
      They should work, they had a bit more room for brakes than my V45s had and they fit C5 brakes, needing just an 1/8" spacer to provide a little breathing room.
      2018 Cruze LT Hatchback
      2003 Suburban 2500 8.1L
      1975 MGB Roadster
      2003 GSX750F Katana
      Yes they do I did it to my 78 ta.
      Sidney Ohio
      Did they need any spacers or anything? What setup did you use? Thanks
      Jul 2010
      Sacramento, CA
      The snowflakes have a ton of clearance. C5's are no issue.
      Sidney Ohio
      Thanks for the info!That's what I wanted to hear!
      Livermore, California
      What did you do for wheel studs and lug nuts? Were you able to fit 1/2-20 studs and lug nuts in the bolt circle of those rims without any problems?
