07-22-2010 #1
Mustang Strut IFS - Lengthening LCA's. Thoughts?
Hey Guys,
I'm doing what you could call trying to make a silk purse out of a sow's ear here but am looking for feedback.
I'm running Fat Man's Strut IFS kit on the front of my '67 Mustang. Its basically the strut/spindle setup out of an '03 Mustang. Overall construction isnt the best but I'm trying to make the best of it.
So, here's my plan that I'm looking to get feedback on. After doing Power Tour this year I got the car back up on jack stands to check everything out. As it turns out the LCA poly bushings are completely destroyed. You can move the wheel about 1/4-1/2" to the front/back of the car. I guess this explains my hunt and peck steering and the inability to get a consitent toe in setting.
My plan is to replace the ghetto bushings with spherical rod ends which arrived earlier in the week. I'm not worried about the potential "harshness" of the rod ends as my rear runs them and I dont find them noisy or rough at all. Anyway, due to the design of the LCA's I am running 1" wheel spacers which results in a significant scrub radius and the associated steering issues. I'd like to get rid of the spacers as then I'd be running the same back spacing as the suspension was originally designed for.
So, my plan is to essentially lengthen the LCA's but about an inch with the obvious adjustability that comes with running rod ends. I'm going to be installing a bump steer kit so I can easily account for the added length in my tie rods. Between the lower strut mount and the upper mount, I'll have no problems getting my recommended 0.5 degrees camber. And by actually pushing the spindle out I'll actually increase camber gain slightly.
I know that there are suspension gurus here so can anyone give me a good reason why I shouldnt do it?
Cheers,
Wes
