      Good Old Pa... You got a friend in Pa LMAO
      Question about turbo cam
      How would motor run without turbo while running a turbo cam?
      PSW
      Aug 2001
      Wilton, CA. (Sacramento)
      Quote Originally Posted by powersstuntworx View Post
      it would run okay, certainly not ideal since turbo cams generally have less exhaust overlap than intake, opposite of a normally aspirated or blower cam.
      But it would definitely drive down the road................
      Jody
      Sep 2002
      So. Cal
      What is the cam specs?
      Should run fine in a N/A set-up. Like Jody said, maybe not the best for top power. Your fueling will be the main issue. When I popped my turbo hose at the track, I was flogging a lot of fuel...
      Ron DeRaad
      68 Camaro RSx
      Darton Sleeved LS9 - 434ci (4.155x4.00)
      AFR LSX245 Heads (12:1cr)
      660hp/588tq
      Feb 2002
      Springfield, MO
      Should run like a stock smogger small block IMO They are usually small with low compression. Should run fine if the timing is set for no boost.
      Jimmy
      69 Camaro Twin Turbo'd
      58 Nomad 348 Baby Rat
      Depends very much on the specs of the engine and the specs on the camshaft. The question is too generic to really give an accurate answer.
