Results 1 to 14 of 14
Thread: 69 Camaro Front Suspension HELP!
07-09-2010 #1
Ok I have a problem BBC, hotchkiss springs, QA1 shocks, 2 " spindles.
The height was too low when I first put the engine in. I then put 2" spacers and everything was good to go. THen a few months later, more sagging and the ride height is too low.
any ideas how to fix this? Can I put a 4" spacer? Do I need different springs?
THanks for helping!
07-09-2010 #2try the sensatrac shocs/ for bbc specfically
it sounds like you may not have bbc springs installed.
Either you will have to change them out or,
you may go to the nearest advance auto and
order a set of shocks specifically for a big block.
they are sensatrac shocks that have a coil over
set up on them.
I have a sbc 355 and i put them on my car and they
are too strong for it, so i have to chage them out. They acually
raised my car, and they fight my springs; I dont have the bbc weight to make them work properly. I think that may be the best and cheapest way. The only other option would be to replace your springs. goodluck
07-09-2010 #3
