Results 1 to 7 of 7
08-27-2010 #1
- Jan 2005
- 19
What MC for LS1 front/rear discs on Chevelle?
I just completed the swap of LS1 front and rear discs onto my '71 Chevelle. I also swapped the clutch/brake/gas pedal assembly and power brake booster from the '99 T/A donor car onto the Chevelle. The car currently has a Chevelle disc/drum master cylinder, and I'm debating what to replace it with.
I have two 4th-gen F-body master cylinders (one from a '94 disc/drum car, and one from a '99 4-wheel disc car) that I've considered using. The problem with these is the steep angle of the reservoir to the master cylinder body (see pic below). Since the Chevelle firewall is nearly vertical, this puts the MC reservoir at a significant backward tilt. I believe the '99 T/A MC is a 1" bore, and since I've got the rest of the braking system from this vehicle, I'm thinking that's probably the bore size I should go with.
Does anyone have suggestions for what MC alternatives I should consider? I'd rather stay away from the older iron designs (personal preference).
I really like the Wilwood 260-8555 master cylinder (above), but I'm having trouble letting go of $200 for it. For reference, I'll be using a Wilwood 260-11179 proportioning valve.
Suggestions would be appreciated. On the other hand, if anybody has experience running the F-body master cylinder with the reservoir at this type of an angle, I'd be interested to hear that as well.
08-27-2010 #2
- Jan 2005
- 19
Derekf mentioned that the booster may place some of the angle on the master cylinder, and he's right. Even with this, though, I believe the reservoir will still be at somewhat of an upward angle. I may be able to do some measuring tonight to get a better idea of what the angle would be.
08-29-2010 #3
