    Results 1 to 20 of 58
      Feb 2007
      USA, TN
      I'll have to research the stepper motor. Is that the same as the IAC?
      The Altenator is a Powermaster CS130. I installed it a little over a year ago when I put the AC in. It puts out 14 - 14.2 at idle depending on the load at the fuse panel. The FI probably sees a little less since it is conncted to the battery. It is a custom wiring harness and everything goes to the fuse panel first; except the FI.
