Results 41 to 58 of 58
Thread: Not so EZ-EFI Question
- Feb 2007
- USA, TN
- 850
I installed an EZ-EFI system on my Nova about six - eight weeks ago. I had two issues, one with the idle and cold driving and the other with fuel pressure. several weeks ago, I resolved the fuel pressure issue which was a filter problem.
I'm still stuck with the inconsistant idle. I've talked to FAST a couple of times but they only want to blame my car. Vacuum leaks and faulty charging system to name two. The car ran perfectly with the carb and was dyno'd by Dyno Speed Racing to get a bench march of power curve and A/F ratios the week before I started the install. I've had it back to Dyno Speed who says there is an issue with the EZ-EFI and I took it to another shop to confirm there isn't a vacuum leak. I'm hoping someone has a suggestion for my problem listed below?
Engine (nothing fancy): ZZ4 with:
Weiand Air Strike intake
1.6 rockers
Comp Cams 26955 springs and matching retainers
Manley Street flow valves (stock size).
Valve job in April.
No porting and the short block is stock.
6 speed transmission.
The symptoms are inconsistent, but this is the trend.
Warm idle, fan and AC off.
If I set the IAC at 15 as recommended by FAST, the idle will fluctuate. It may start as a 100 -200 RPM swing from my idle of 800 RPM. and eventually fluctuate up and down enough for the engine to die. If I blip the throttle to 1200 RPM, it will start to idle correctly for a while again. At this setting, my vacuum will fluctuate.
If I plug the IAC hole or set the IAC to 5 (its lowest setting), it will idle near perfectly. the Idle will sometimes drop to 500 RPM when I let off the gas but recover and idle fine. At this setting, my vacuum is a steady 16 lbs.
Warm Idle, fan and/or AC on or cold.
Anything that causes the IAC count to increase will make the problem worse. With the IAC set at 15, the RPM fluctuation can be 500+ RPM. It does sound like a massive vacuum leak but I don't have a leak. I have to constantly blip the throttle to keep it idleing. if I have to stop quick and can't hit the gas, it will die.
With the IAC at 5, it idles much better. The fluctuations are a consistant 100 - 200 RPM and occassionally higher. It rarely stalls with the IAC at 5.
Cold and AC on:
IAC at recommended setting, it is a battle to keep it running. With it set at 5, It will stall once or twice until it warms up a little.
The most frustrating part:
Once the engine stalls, you have to turn the key off and wait at least 5 seconds to restart. If you wait 4 seconds and try, You will have to wait 5 more seconds. This can seem like an eternity when stalled at a green light.
Other than Idle, the system seems to be working pretty good. My MPG is down about 20%, but I think it is getting better now that the computer is learning. It does take a couple of weeks of daily driving for the computer to learn the engine
