      Clovis, Ca
      Bump Stop on Linked/coil over suspension?
      What are you guys using for bump stops on a linked/coil over rear suspension?
      On my 69 Camaro, I have about 1” of upward travel to the factory bump stop. It looks like the easiest way to get the travel and the bump stop is to run a bump stop on the shock shaft to limit up upward travel.
      Is that what most are doing with DSE suspension?
      Dave
      May 2002
      Northern California
      coil over shaft stops are great.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Clovis, Ca
      Got to looking around and I think I will just put a set of of the QA1 1.25" bumpers on the shocks and take the bump stops off the frame.
      So. Cal.
      One other option to look at is replacing the frame bump stops you have with some progressive rate bump stops.
      Bump stops have changed abit. Builders have noticed that a progressive bump stop can actually be an active part in the suspension. Not just a fail safe method of stopping hard parts from bottoming out.
      And unfortunately, the progressive bump stops can get kinda pricey.
      Google search progressive bump stops. Alot of choices. JR
      http://www.google.com/#hl=en&source=...5c0c6008861bf6
      What I write is opinion, none of it is factual. 2010
      Even though I'm conscious it doesn't mean I'm coherent. 2011
      I'm getting better with age. Best thing about old age is I don't know any better. 2012
      Oct 2009
      New Derry, PA
      Only downside to the coilover stops is that they are usually made from closed cell foam and will degrade if exposed to oil, antifreeze or other common automotive fluids.
      JRouche is right about the stops being helpful tuning aids. Carroll Smith had a section about trimming Koni bump stops in "Prepare to Win". That was about 1974, so the idea's been around...
